Discuss
Bosch stuck in drain cycle
 in
Dishwasher Repair
My Bosch SHU9922UC dishwasher is stuck in drain cycle. This had happened one time before and after removing the machine
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Bosch stuck in drain cycle
  #1 (permalink)
Old 05-24-2008, 03:36 PM
89fxrp 89fxrp is offline
Junior Member
89fxrp is on a distinguished road
Unhappy Bosch stuck in drain cycle
Model Number: SHU9922UC   Brand: Bosch   Age: 5 - 10 years
My Bosch SHU9922UC dishwasher is stuck in drain cycle. This had happened one time before and after removing the machine and removed the Water level switch housing and the Level switch assembly then reinstalling these components it started working correctly again. I have tried the diagnostics procedure and what is indicated is 2 faults "Heater Fault" and "Water filling fault". There is reason to believe it is not the heater or the fill solenoid. Currently the machine is stuck in drain and the pump will not stop running and fill solenoid does not activate. I believe the failed component is either the Level switch housing or level switch or perhaps the Level switch housing assembly Any help would be appreciated.
Jeff
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Bosch dishwasher stuck on rinse cycle JDDrake Dishwasher Repair 2 04-05-2008 11:10 AM
Bosch SHU5312 - stuck in cycle DanS2 Dishwasher Repair 1 04-01-2008 06:22 PM
stuck in drain cycle kyrboyd Dishwasher Repair 0 12-30-2007 10:27 PM
Stuck in drain cycle glbray1 Dishwasher Repair 0 11-04-2007 09:38 AM
Maytag dishwasher stuck on drain cycle ak47jazzfan Dishwasher Repair 3 10-15-2007 11:35 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
