| » GE washer will not fill with water |
| By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use. |
Model Number: pdw7880g00ss Brand: GE Age: 1 - 5 years
GE dishwasher will not let water fill.if you put water in yourself it will spray. and wash but as soon as the water has pumped out it will not rinse.
Check the water valve (#744 on this diagram). The solenoid might be bad, in which case replace the valve. Or the screen inside the valve may be clogged, clean it.
| Display Modes | |
| Washer is slow to fill | Dbowls | Washer Repair | 1 | 08-30-2007 02:22 PM |
| Washer won't drain during spin cycle. Water Pump Belt discovered on floor | sandydjdm | Washer Repair | 1 | 08-14-2007 07:41 PM |
| washer will only run hot water | tjstenz | Washer Repair | 1 | 08-10-2007 10:16 AM |
