Discuss
GE dishwasher won't clean
 in
Dishwasher Repair
I am so frustrated. My husband is not a fix it type of guy, and I would like to try
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » GE dishwasher won't clean
  #1 (permalink)
Old 05-22-2008, 03:25 PM
gayleinsw gayleinsw is offline
Junior Member
gayleinsw is on a distinguished road
Default GE dishwasher won't clean
Model Number: EDW4000G00cc   Brand: GE   Age: 5 - 10 years
I am so frustrated. My husband is not a fix it type of guy, and I would like to try to fix our dishwasher. So many of the dishes come out dirty. So, we called out the repairman, and he said it needed to be cleaned under the grate, and possibly replace the filter under the grate. He wanted to charge over $200. I would like to surprise my husband and save a ton of money. I have removed the arm and cleaned it, and now don't know how to remove the rest to get to the grate. And, I won't know how to remove the grate.
Thanks,
cindy
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 05-23-2008, 02:52 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
Remove the retaining screw from the back wall that atatches the feed tube to the upper spray arm, then twist off the feed tube that supplied water to it.Then remove torq screws holding down the top of the pump.
Before doing this, verify enough water is entering the dishwasher, should be just below the heater.Also, verify your water temperature is above 130 degrees.
Post results.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kitchen Aid Dishwasher Won't Clean Top Rack Items optiman Dishwasher Repair 5 11-07-2008 12:13 AM
Kenmore Dishwasher Upper Rack Does not Clean san Dishwasher Repair 6 04-30-2008 06:58 PM
Dishwasher not getting dishes clean alidor1873 Dishwasher Repair 1 02-29-2008 04:12 PM
Maytag Dishwasher not getting dishes clean fillhardfarm Dishwasher Repair 1 01-18-2008 01:49 PM
Bosch Dishwasher not clean Savannah9999 Dishwasher Repair 1 09-21-2007 10:52 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
