House has soft water, use dishwasher tabs Load dishes and soap, run tap to get hot water Press normal wash, hi temp scrub and start Fills tub motor starts, panel reads sensing, hear pump working Approx 20 min. later come back, pump stopped Lights flashing for normal wash, hi temp scrub and washing Open door, soap door open water in tub (did not check temp) Leave until morning, close door, press start seems fine Get home from work, sensing light on Thanks
