| » Water Valve replacement on Bosch Dishwasher Lasted Seven Months! |
Model Number: SHU43C02UC/17 Brand: Bosch Age: 1 - 5 years
I replaced the water valve on my bosch dishwasher approx. 7 months ago and now it appears to have gone out again. Is this a common problem with bosch water valves?
If the valve is sticking open(won't shut off) you may have sediment in the line that is keeping the valve from shutting. If it is not operating, check that the wiring terminals are tight. Loose connections can create heat that will cause the solenoid to burn out faster. It is possible that you just got a bad valve.
| Display Modes | |
| Is my replacement Water Valve bad too? | FredMC | Dishwasher Repair | 2 | 08-24-2009 03:03 PM |
| Bosch - How do u replace water valve? | jbomber | Dishwasher Repair | 5 | 11-02-2008 05:47 PM |
| Bosch water valve wiring | harelt | Dishwasher Repair | 7 | 10-30-2008 11:16 AM |
| Replacing water valve assembly on brand new Bosch | NickB | Dishwasher Repair | 2 | 03-28-2008 03:01 AM |
