Discuss
Bosch - No fill, no heat, no drain
 in
Dishwasher Repair
A short while back, the washer was running and went into drain mode and would not stop. The display looked
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Bosch - No fill, no heat, no drain
  #1 (permalink)
Old 05-18-2008, 11:55 AM
Junior Member
Coyote is on a distinguished road
Default Bosch - No fill, no heat, no drain
Model Number: SHX46L05/18   Brand: Bosch   Age: 1 - 5 years
A short while back, the washer was running and went into drain mode and would not stop. The display looked "weak" and no buttons would do anything. Figured it was the control module, ordered one from Appliance Pros here, installed it, and dishwasher came to life, sort of. It would not fill with water, so to try to jump start it, I filled it by hand to the normal running level. Starting the cycle would run normally, but it would never heat, no drain, and run to the end of the cycle and just keep going. Trying the cancel and drain technique I saw for a similar model, (and suspect it might no be meant to do the same, but I dont know) it still would not drain. I double checked all the connections to the control module, emptied the water and tried again, with no results.
I wonder what could be issue now. Perhaps the module going bad and it running like that for a undetermined amount of time before I realized it was borked cooked something else?
Edit and update:
Pulled washer out to check for anything else that might be an issue. Now it fills - weird, still wont drain or heat...
Ads By Google
Related Models
Bosch SHX56B02 UC/14 (FD 8211-)
Bosch SHX56B05 UC/14 (FD 8211-)
Bosch SHX56B06 UC/14 (FD 8211-)
Bosch SHX99B05 UC/14 (FD 8212-)
Bosch SHX99B06 UC/14 (FD 8212-)
Bosch SHY56A02 UC/14 (FD8301-)
Bosch SHY56A05 UC/14 (FD8301-)
Bosch SHY56A06 UC/14 (FD8301-)
Bosch SHY66C02 UC/14 (FD8301-)
Bosch SHY66C05 UC/14 (FD8301-)
Bosch SHY66C06 UC/14 (FD8301-)
Bosch SHY99A02 UC/14 (FD 8212-)
Bosch SHY99A05 UC/14 (FD 8212-)
Bosch SHY99A06 UC/14 (FD 8212-)
Amana SI19E Ref - SXS/I&W
General Electric SIG7010ET1WG Electric dryer
International SILVER22 Ref - SXS/I&W
International SILVER24 Ref - SXS/I&W
Maytag SK525-2W  Ref - Sxs
Maytag SK535-2  Ref - SXS/I&W
Gaggenau SK590-2  Ref - Bottom Mounts
Hardwick SKG4622MGA639R Range - F/s Cont Clean Gas
Hardwick SKG4622MGW639R Range - F/s Cont Clean Gas
Hardwick SKG9611A540R Range - F/s Cont Clean Gas
Hardwick SKG9611W540R Range - F/s Cont Clean Gas
Amana SKI22F Ref - SXS/I&W
Amana SKI22F-A Ref - SXS/I&W
Amana SKI22F-C Ref - SXS/I&W
Amana SKI22F-G Ref - SXS/I&W
Amana SKI22FL Ref - SXS/I&W
Hardwick SKJ7141819DE Walloven - Cont Clean Gas
Maytag SL10AA Stacked Laundry - Ele
Maytag SL10AA-A01 Stacked Laundry - Ele
Maytag SL10AN Stacked Laundry - Ele
Maytag SL10AN-A00 Stacked Laundry - Ele
Maytag SL10AN-A01 Stacked Laundry - Ele
Maytag SL10AN-A02 Stacked Laundry - Ele
Maytag SL10AN-A03 Stacked Laundry - Ele
Maytag SL11AA Stacked Laundry - Ele
Maytag SL11AN Stacked Laundry - Ele
General Electric SL208 Room air conditioner
General Electric SL210 Room air conditioner
General Electric SL212 Room air conditioner
General Electric SL214 Room air conditioner
General Electric SL217 Room air conditioner
General Electric SL220 Room air conditioner
General Electric SL223 Room air conditioner
Amana SL22F Ref - SXS/I&W
Amana SL22F-A Ref - SXS/I&W
Amana SL22F-C Ref - SXS/I&W
Amana SL22F-G Ref - SXS/I&W
Amana SL22F-L Ref - SXS/I&W
Amana SL22G Ref - SXS/I&W
Amana SL22GL Ref - SXS/I&W
Amana SL22JB Ref - SXS/I&W
Amana SL22MBG Ref - SXS/I&W
Amana SL22MBL Ref - SXS/I&W
Amana SL22MBW Ref - SXS/I&W
Amana SL25G Ref - SXS/I&W
Amana SL25GL Ref - SXS/I&W
Amana SL25H Ref - SXS/I&W
Amana SL25J Ref - SXS/I&W
Amana SL25M2L Ref - SXS/I&W
Amana SL25M2W Ref - SXS/I&W
Amana SL25MG Ref - SXS/I&W
Amana SL25ML Ref - SXS/I&W
Amana SL25MW Ref - SXS/I&W
Amana SLD22JB Ref - SXS/I&W
Amana SLD22MB2L Ref - SXS/I&W
Amana SLD22MB2W Ref - SXS/I&W
Amana SLD22MBG Ref - SXS/I&W
Amana SLD22MBL Ref - SXS/I&W
Amana SLD22MBW Ref - SXS/I&W
Amana SLD25J Ref - SXS/I&W
Amana SLD25JB Ref - SXS/I&W
Amana SLD25JP Ref - SXS/I&W
Amana SLD25M2G Ref - SXS/I&W
Amana SLD25M2L Ref - SXS/I&W
Amana SLD25M2W Ref - SXS/I&W
Amana SLD25MB2L Ref - SXS/I&W
Amana SLD25MB2W Ref - SXS/I&W
Amana SLD25MBG Ref - SXS/I&W
Amana SLD25MBL Ref - SXS/I&W
  #2 (permalink)
Old 05-25-2008, 06:56 AM
Junior Member
Default
Resolved issue. Pulling unit apart, I found that mice had chewed thru a few of the wires - I believe this might have been the cause of a short and the toasting of the original control unit. Works like a champ now.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
bosch shu9925 - drain pump works, won't drain after cycle mjbarr Dishwasher Repair 0 10-16-2009 01:11 PM
Timer will only advance to fill and wash not drain (have to manually move to drain) zibdi1 Dishwasher Repair 0 06-15-2009 03:47 PM
Bosch DW tub does Not fill BuilderBarb Dishwasher Repair 0 02-16-2009 12:51 PM
Bosch DW does not fill or drain properly carol kittelson Dishwasher Repair 5 10-02-2008 11:10 AM
Bosch DW does not fill or drain properly carol kittelson Dishwasher Repair 1 09-26-2008 02:31 PM
