Discuss
Whirlpool timer hangs up in wash cycle @ 36minutes
 in
Dishwasher Repair
I have recently installed a new heating element and circuit control board, both were needed, however new board hangs up
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Whirlpool timer hangs up in wash cycle @ 36minutes
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 05-16-2008, 07:56 AM
BRB BRB is offline
Junior Member
BRB is on a distinguished road
Default Whirlpool timer hangs up in wash cycle @ 36minutes
Model Number: GU1500XTKQ0 GOLD QUIET PARTNER IV   Brand: Whirlpool   Age: 5 - 10 years
I have recently installed a new heating element and circuit control board, both were needed, however new board hangs up in the normal wash cycle @ 36 minutes, the unit keeps running, however the "sensing/soaking" and "water heating" lights are on, I can perform the procedure to enable advancing the cycle and when I do that, the 2 lights go off and the timer window begins to advance and the wash cycle progresses to it's normal end, I have checked the water and it is hot, I have reset the board a number times and that hasn't helped, the old board stuck at 76 minutes with the "water heating" light on and I think that burned out the original heating element. Any HELP would be appreciated.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 05-16-2008, 02:22 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
As part of normal operation, the dishwasher pauses 2 or 3 times during the cycle for thermal holds and advances once temperature is met.
If temperature of the water entering the dishwasher is at least 120°F and the soil level is light than the real time to complete the "Normal wash" is about 90 minutes. The cooler the water the longer the cycle time.
Measure the water temperature in the dishwasher during a thermal hold and if it's more than 160°F then replace the thermistor.
- The part number for the thermistor is AP3039201
Here are the break down diagrams for the Whirlpool dishwasher Model GU1500XTKQ0
__________________
Professional appliance repair services in Orange County, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
DW hangs up in wash/rinse cycles OrvD Dishwasher Repair 10 06-24-2008 05:40 AM
Timer stops after wash cycle YODAUSA Washer Repair 5 05-13-2008 12:12 PM
Whirlpool dishwasher makes loud howling noise during wash cycle mj04 Dishwasher Repair 6 05-11-2008 01:47 PM
Whirlpool makes noise at end of wash cycle brfiel Washer Repair 1 09-21-2007 10:01 AM
Can not select wash cycle - stuck on scrub wash luke Dishwasher Repair 0 08-20-2007 08:38 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
