| » Frigidaire dishwasher won't power |
Model Number: FDB635RFS6 Brand: Frigidaire Age: 5 - 10 years
I have a Frigidaire dishwasher that's been working fine for a few years. I think it's about 5 years old at this point. Tried to use it today, and it looks like it's not getting power. Checked the breaker, don't see any loose wires, etc.
Is there a reset switch somewhere, or an internal breaker? Any help is appreciated... |
remove bottom cover, there is a square aluminum box ,remove cover, the power wires are there, there should be two marrete conectors, carefully remove them, check for burnt wire, if you have a multimeter, check to see if you have 110 volts across these 2 wires, be careful these wires will be alive if breaker is good, if there is voltage the problem could be door switch in control panel.
__________________
I pulled off the square aluminum box ,remove cover, the power wires are there The two white wires were burnt! I followed the white wires up behind the door an everyting looked ok. If those wires are burnt behind the alum box what do you think I should look at now?
Thanks! |
| Display Modes | |
| dishwasher with no power | tmcginnis@bak.rr.com | Dishwasher Repair | 1 | 04-29-2008 06:16 PM |
| Frigidaire Dishwasher No Power | pzanghi | Dishwasher Repair | 1 | 01-20-2008 11:12 AM |
| Frigidaire has no power | bilnjon | Dishwasher Repair | 1 | 01-15-2008 02:42 PM |
| Frigidaire microwave power cord | blar | Microwave Repair | 1 | 11-14-2007 09:00 PM |
| Frigidaire elec dryer: Power, but won't start | tidajo | Dryer Repair | 4 | 11-02-2007 05:21 PM |
