Discuss
Bosch won't countdown to zero
 in
Dishwasher Repair
Hi All. First time user. Would appreciate your help with this problem on my Bosch SHU6805UC/U12 dishwasher. The unit counts
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Bosch won't countdown to zero
  #1 (permalink)
Old 08-29-2007, 11:34 AM
Junior Member
StratLou is on a distinguished road
Default Bosch won't countdown to zero
Model Number: shu6805uc/12   Brand: Bosch   Age: 5 - 10 years
The unit counts down to 1 and then hangs there indefinitely but keeps circulating. Upon opening the door, it can be seen that sudsy water remains filling the bottom of the tub. Also the water is hot and was being circulated but will not drain (or rinse?). There is what sounds like a rhythmic "vaccuum" noise as well, probably just the pump working.
After this was observed, I tried a different approach as per the owners manual. I turned the d/w on and then pressed the "scrub wash" and "delicate buttons" at the same time to reset the wash cycle to the beginning and drain the tub. Now all I get is "2H" in the indicator window when I try to start a new cycle. If I let it run, it appears to fill and begin the wash function. The water now only gets warm and not hot. Also, it begins to count down, at one point (45 mins? don't remember exactly) down to 1 and won't go to zero. Any idea if I need to perform any more specific tests? What would need repair/replacement as a result. Thanks very much for any help you can give me.
Regards,
Lou
Ads By Google
Related Models
Bosch SHU6806 UC/06 (FD 7705-7912)
Bosch SHU6806 UC/11 (FD 8001-8003)
Bosch SHU6806 UC/12 (FD 8003-)
Whirlpool SHU70000
Whirlpool SHU70001
Whirlpool SHU70010
Whirlpool SHU70040
Whirlpool SHU70041
Whirlpool SHU70050
Whirlpool SHU70051
Whirlpool SHU70052
Whirlpool SHU75000
Whirlpool SHU75010
Whirlpool SHU75040
Whirlpool SHU75042
Whirlpool SHU80000
Whirlpool SHU80001
Whirlpool SHU80010
Whirlpool SHU80040
Whirlpool SHU80041
Whirlpool SHU80042
Bosch SHU8802 UC/12 (FD 8105-)
Bosch SHU8805 UC/12 (FD 8105-)
Bosch SHU8806 UC/12 (FD 8105-)
Bosch SHU8812 UC/12 (FD 8105-)
Bosch SHU8815 UC/12 (FD 8105-)
Bosch SHU8816 UC/12 (FD 8105-)
Whirlpool SHU90000
Whirlpool SHU90001
Whirlpool SHU90002
Whirlpool SHU90010
Whirlpool SHU90040
Whirlpool SHU90041
Whirlpool SHU90050
Whirlpool SHU99000
Whirlpool SHU99001
Bosch SHU9902 UC/06
Bosch SHU9902 UC/06 (FD 7905-7912)
Whirlpool SHU99040
Whirlpool SHU99041
Bosch SHU9905 UC/06
Bosch SHU9905 UC/06 (FD 7905-7912)
Whirlpool SHU99050
Whirlpool SHU99052
Whirlpool SHU99053
Bosch SHU9906 UC/06
Bosch SHU9906 UC/06 (FD 7905-7912)
Bosch SHU9912 UC/06
Bosch SHU9912 UC/06 (FD 7908-8002)
Bosch SHU9912 UC/11
Bosch SHU9912 UC/11 (FD 8002-8003)
Bosch SHU9912 UC/12
Bosch SHU9912 UC/12 (FD 8003-)
Bosch SHU9915 UC/06
Bosch SHU9915 UC/06 (FD 7908-8002)
Bosch SHU9915 UC/11
Bosch SHU9915 UC/11 (FD 8002-8003)
Bosch SHU9915 UC/12
Bosch SHU9915 UC/12 (FD 8003-)
Bosch SHU9916 UC/06
Bosch SHU9916 UC/06 (FD 7908-8002)
Bosch SHU9916 UC/11
Bosch SHU9916 UC/11 (FD 8002-8003)
Bosch SHU9916 UC/12
Bosch SHU9916 UC/12 (FD 8003-)
Bosch SHU9922 UC/12 (FD 8003-)
Bosch SHU9925 UC/12 (FD 8003-)
Bosch SHU9926 UC/12 (FD 8003-)
Bosch SHU9952 UC/12 (FD 8105 -)
Bosch SHU9955 UC/12 (FD 8105 -)
Bosch SHU9956 UC/12 (FD 8105 -)
Bosch SHV4303 UC/06
Bosch SHV4303 UC/06 (FD 7712-8002)
Bosch SHV4303 UC/11
Bosch SHV4303 UC/11 (FD 8002-8003)
Bosch SHV4303 UC/12
Bosch SHV4303 UC/12 (FD 8003-)
Bosch SHV46C03 UC/14 (FD 8211-)
Bosch SHV4803 UC/06
Bosch SHV4803 UC/06 (FD 7712-7812, 7905-7907)
Bosch SHV4803 UC/07
Bosch SHV4803 UC/07 (FD 7812-7905, 7907-8010)
Bosch SHV4803 UC/12
Bosch SHV4803 UC/12 (FD 8010-)
Bosch SHV66A03 UC/14 (FD 8301-)
Bosch SHV6803 UC/12 (FD 8105 -)
Bosch SHV99A03 UC/14 (FD 8212-)
Hoover SHWA2501A Washer - Top Loading
Hoover SHWA2501W Washer - Top Loading
Hoover SHWA2506A Washer - Top Loading
Hoover SHWA2506AT Washer - Top Loading
Hoover SHWA2506W Washer - Top Loading
Hoover SHWA2506WT Washer - Top Loading
Hoover SHWA2507A Washer - Top Loading
Hoover SHWA2507V Washer - Top Loading
Hoover SHWA2507W Washer - Top Loading
Bosch SHX33A02 UC/14 (FD 8211-)
Bosch SHX33A05 UC/14 (FD 8211-)
Bosch SHX33A06 UC/14 (FD 8211-)
Bosch SHX43E02 UC/14 (FD 8211-)
Bosch SHX43E05 UC/14 (FD 8211-)
Bosch SHX43E06 UC/14 (FD 8211-)
Bosch SHX46A02 UC/14 (FD 8211-)
Bosch SHX46A05 UC/14 (FD 8211-)
Bosch SHX46A06 UC/14 (FD 8211-)
Bosch SHX46A07 UC/14 (FD 8211-)
Bosch SHX46B02 UC/14 (FD 8211-)
Bosch SHX46B05 UC/14 (FD 8211-)
Bosch SHX46B06 UC/14 (FD 8211-)
Bosch SHX46B07 UC/14 (FD 8211-)
Bosch SHX56B02 UC/14 (FD 8211-)
Bosch SHX56B05 UC/14 (FD 8211-)
Bosch SHX56B06 UC/14 (FD 8211-)
Bosch SHX99B05 UC/14 (FD 8212-)
Bosch SHX99B06 UC/14 (FD 8212-)
Bosch SHY56A02 UC/14 (FD8301-)
Bosch SHY56A05 UC/14 (FD8301-)
Bosch SHY56A06 UC/14 (FD8301-)
Bosch SHY66C02 UC/14 (FD8301-)
Bosch SHY66C05 UC/14 (FD8301-)
  #2 (permalink)
Old 08-29-2007, 02:24 PM
Admin / APP Team's Avatar
Administrator
APP Team
Admin / APP Team has disabled reputation
Default
Sounds like a classic case of Bosch's "controlmodulitis". Common problem. I smell recall in the air, but my guess is it's gonna stink for a while before the recall is issued.
New Bosch control module is #1 on this diagram
  #3 (permalink)
Old 08-29-2007, 09:58 PM
Junior Member
Default
Ran through the steps in the dishwasher troubleshooting chart and came up with a code "2" displayed which is a heating fault (the wash water never even got warm during the test cycle). In addition to the control module, could there be anything else that failed and would need replacing as well or is the control module, in this case, responsible for the no heat as well as the not counting down to zero issues. Many thanks again.
  #4 (permalink)
Old 08-29-2007, 10:50 PM
Administrator
APP Team
Default
Usually, the thing that fails is the heater resistor on the module itself. That is why you're getting a "heating" related error. You can visually inspect the board and will probably notice the burnt out resistor.
  #5 (permalink)
Old 09-04-2007, 06:28 AM
Junior Member
WaiverWire is on a distinguished road
Default
I had the exact same problem 3 years ago on by Bosch SHU5315....and it started again last night. Last time I had to replace the module, and am planning on doing the same again.
Question....I have noticed that the part may be a little different when it comes to the light configuration. Is it still as easy to replace as the older model part???
  #6 (permalink)
Old 03-10-2009, 07:35 PM
Junior Member
kellman@nyc.rr.com is on a distinguished road
Default
I have the same problem and it is also 7 years old. Was there a recall? If so, please send me the information. Thank you.
  #7 (permalink)
Old 03-10-2009, 08:18 PM
Junior Member
Default
kellman........sorry no recall.
I have had to replace mine twice. I have been told to be more careful when using the stainless steel spray cleaner on the front.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Countdown Display INOP, Washer cycles normally Julia Dishwasher Repair 1 01-17-2010 04:07 AM
Bosch D/W Countdown Window Lens Broken csrb Dishwasher Repair 0 09-10-2009 05:36 PM
Maytag microwave no heat & display rapid countdown jjssdd Microwave Repair 2 06-17-2009 02:41 AM
Countdown timer sticks FJ Pierce Dishwasher Repair 2 03-05-2008 01:14 PM
Bosch memyer Dishwasher Repair 2 12-19-2007 05:31 AM
