Discuss
bosch classix not filling up
 in
Dishwasher Repair
Here's hoping someone can help. My dishwasher was running fine until we moved and it went in a shed for
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » bosch classix not filling up
  #1 (permalink)
Old 02-17-2010, 02:30 PM
Junior Member
kes_0 is on a distinguished road
Default bosch classix not filling up
Model Number: classix   Brand: Bosch   Age: 5 - 10 years
Here's hoping someone can help. My dishwasher was running fine until we moved and it went in a shed for 11months. Now it is reinstalled but will not fill with water. I opened the side and rinsed out all the pipe bits which appeared to resolve it as when I put it on a rinse cyle it did everything it should. But the next time I tried it it wouldn't fill again. The pipe bits seem to be clear so the only other bit is the red float at the bottom but it will move if you manually do it with no bother. Its as if it doesn't know when to move to let the water in.Once you manually move it then water flows in fine.
Any ideas please?
Kes
Ads By Google
Related Models
 CLCG500FW0 CROSLEY/LAUNDRY CENTER
 CLCG900FW0 CROSLEY/LAUNDRY CENTER
Maytag CLE700 Range - Std Mwave Ele
Maytag CLE750 Range - Std Mwave Ele
Maytag CLG600 Range - Std Mwave Gas
Maytag CLG601 Range - Std Mwave Gas
Magic Chef CLL1101ADW Range - S/c F/s Ele
Magic Chef CLL1120ADH Range - F/s Std Gas
International CLR1100AJQ Range - F/s Std Gas
International CLR1100AJW Range - F/s Std Gas
Magic Chef CLY1610ADB Rv Range - Gas
Magic Chef CLY1610ADQ Rv Range - Gas
Magic Chef CLY1610ADW Rv Range - Gas
Magic Chef CLY1610BDB Rv Range - Gas
Magic Chef CLY1610BDQ Rv Range - Gas
Magic Chef CLY1610BDW Rv Range - Gas
Magic Chef CLY1611BDH Rv Range - Gas
Magic Chef CLY1612ADH Rv Range - Gas
Magic Chef CLY1612BDH Rv Range - Gas
Magic Chef CLY1620ADB Rv Range - Gas
Magic Chef CLY1620ADQ Rv Range - Gas
Magic Chef CLY1620ADS Rv Range - Gas
Magic Chef CLY1620ADW Rv Range - Gas
Magic Chef CLY1620BDB Rv Range - Gas
Magic Chef CLY1620BDS Rv Range - Gas
Magic Chef CLY1620BDW Rv Range - Gas
Magic Chef CLY1628ADB Rv Range - Gas
Magic Chef CLY1628BDB Rv Range - Gas
Magic Chef CLY1631ADB Rv Range - Gas
Magic Chef CLY1631ADH Rv Range - Gas
Magic Chef CLY1631ADL Rv Range - Gas
Magic Chef CLY1631BDB Rv Range - Gas
Magic Chef CLY1631BDH Rv Range - Gas
Magic Chef CLY1631BDL Rv Range - Gas
Magic Chef CLY1631BDT Rv Range - Gas
Magic Chef CLY1632ADB Rv Range - Gas
Magic Chef CLY1632ADH Rv Range - Gas
Magic Chef CLY1632ADL Rv Range - Gas
Magic Chef CLY1632BDB Rv Range - Gas
Magic Chef CLY1632BDH Rv Range - Gas
Magic Chef CLY1632BDL Rv Range - Gas
Magic Chef CLY1632BDT Rv Range - Gas
Magic Chef CLY1638BDB Rv Range - Gas
Magic Chef CLY1641ADB Rv Range - Gas
Magic Chef CLY1641ADH Rv Range - Gas
Magic Chef CLY1641ADL Rv Range - Gas
Magic Chef CLY1641BDB Rv Range - Gas
Magic Chef CLY1641BDH Rv Range - Gas
Magic Chef CLY1641BDL Rv Range - Gas
Magic Chef CLY1641BDT Rv Range - Gas
Magic Chef CLY1642ADH Rv Range - Gas
Magic Chef CLY1642BDH Rv Range - Gas
Magic Chef CLY1645BDB Rv Range - Gas
Magic Chef CLY1662ADH Rv Range - Gas
Magic Chef CLY1662BDH Rv Range - Gas
Magic Chef CLY2210ADB Rv Range - Gas
Magic Chef CLY2210ADW Rv Range - Gas
Magic Chef CLY2210BDB Rv Range - Gas
Magic Chef CLY2212ADH Rv Range - Gas
Magic Chef CLY2212BDH Rv Range - Gas
Magic Chef CLY2220ADB Rv Range - Gas
Magic Chef CLY2220ADW Rv Range - Gas
Magic Chef CLY2220BDB Rv Range - Gas
Magic Chef CLY2220BDW Rv Range - Gas
Magic Chef CLY2231ADH Rv Range - Gas
Magic Chef CLY2231BDB Rv Range - Gas
Magic Chef CLY2231BDH Rv Range - Gas
Magic Chef CLY2232ADH Rv Range - Gas
Magic Chef CLY2232BDB Rv Range - Gas
Magic Chef CLY2232BDH Rv Range - Gas
Magic Chef CLY2235BDB Rv Range - Gas
Magic Chef CLY2241ADH Rv Range - Gas
Magic Chef CLY2241ADL Rv Range - Gas
Magic Chef CLY2241BDB Rv Range - Gas
Magic Chef CLY2241BDH Rv Range - Gas
Magic Chef CLY2241BDL Rv Range - Gas
Magic Chef CLY2241BDT Rv Range - Gas
Magic Chef CLY2242ADB Rv Range - Gas
Magic Chef CLY2242ADH Rv Range - Gas
Magic Chef CLY2242ADL Rv Range - Gas
Magic Chef CLY2242BDB Rv Range - Gas
Magic Chef CLY2242BDH Rv Range - Gas
Magic Chef CLY2242BDL Rv Range - Gas
Magic Chef CLY2242BDT Rv Range - Gas
Magic Chef CLY2245BDB Rv Range - Gas
Magic Chef CLY2245BDT Rv Range - Gas
Magic Chef CLY2248BDB Rv Range - Gas
Magic Chef CLY2249BDB Rv Range - Gas
Magic Chef CLY2253ADB Rv Range - Gas
Magic Chef CLY2253BDB Rv Range - Gas
Magic Chef CLY2260ADB Rv Range - Gas
Magic Chef CLY2260ADW Rv Range - Gas
Magic Chef CLY2260BDB Rv Range - Gas
Magic Chef CLY2260BDW Rv Range - Gas
Magic Chef CLY2262ADH Rv Range - Gas
Magic Chef CLY2262BDH Rv Range - Gas
Magic Chef CLZ8501ADL Rv Surface Unit - Gas
Magic Chef CLZ8501BDB Rv Surface Unit - Gas
Magic Chef CLZ8501BDH Rv Surface Unit - Gas
Magic Chef CLZ8501BDL Rv Surface Unit - Gas
Magic Chef CLZ8501BDT Rv Surface Unit - Gas
Magic Chef CLZ8502ADB Rv Surface Unit - Gas
Magic Chef CLZ8502ADH Rv Surface Unit - Gas
Magic Chef CLZ8502ADL Rv Surface Unit - Gas
Magic Chef CLZ8502BDB Rv Surface Unit - Gas
Magic Chef CLZ8502BDH Rv Surface Unit - Gas
Magic Chef CLZ8502BDL Rv Surface Unit - Gas
Magic Chef CLZ8502BDT Rv Surface Unit - Gas
Magic Chef CLZ8505BDB Rv Surface Unit - Gas
Magic Chef CLZ8505BDT Rv Surface Unit - Gas
Magic Chef CLZ8508BDB Rv Surface Unit - Gas
Magic Chef CLZ8509BDB Rv Surface Unit - Gas
Magic Chef CLZ8550ADB Rv Surface Unit - Gas
Magic Chef CLZ8550ADQ Rv Surface Unit - Gas
Magic Chef CLZ8550ADW Rv Surface Unit - Gas
Magic Chef CLZ8560ADB Rv Surface Unit - Gas
Magic Chef CLZ8560ADQ Rv Surface Unit - Gas
Magic Chef CLZ8560ADW Rv Surface Unit - Gas
Whirlpool CM02743BL1
Jenn-Air CM100 Surface Base Unit - Ddraft Ele
  #2 (permalink)
Old 02-17-2010, 03:41 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Kes,
The first failure suspect in such situation is always a water inlet valve. Check if there is 120 VAC to the water valve while the control calls for water fill. If there is proper voltage, replace the water valve.
If you need the correct part number, post the complete model number of the dishwasher.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Bosch Dishwasher keeps filling with water when not in use. Paula Ratermann Dishwasher Repair 1 08-03-2009 08:30 PM
bosch classix wont drain 123lynne Dishwasher Repair 0 07-26-2009 09:52 AM
Bosch Dishwasher not filling with enough water gilbert ratchet Dishwasher Repair 0 07-23-2008 03:18 PM
Bosch dishwasher not filling with water rritter Dishwasher Repair 3 01-17-2008 08:10 PM
Bosch keeps filling with water noisybosch Dishwasher Repair 1 11-18-2007 04:26 AM
