Discuss
Won't agitate but spins
 in
Dishwasher Repair
The motor clicks when it comes time to agitate. The motor bumps slightly in one direction but never backs up.
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Won't agitate but spins
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 05-12-2008, 01:06 PM
BobKrause56 BobKrause56 is offline
Junior Member
BobKrause56 is on a distinguished road
Question Won't agitate but spins
Model Number: LWA80AW   Brand: Amana   Age: More than 10 years
The motor clicks when it comes time to agitate. The motor bumps slightly in one direction but never backs up. The machine will spin but seems to take a little longer than I remember to spin up to speed. I get 5 Ohms across the motor and no connection to ground.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 05-12-2008, 05:37 PM
bambiblaster bambiblaster is offline
Senior Expert
APP Volunteer
bambiblaster is on a distinguished road
Default
You need to remove the agitator and check to see if number 11 is stripped or not... it is splined
  #3 (permalink)
Old 05-13-2008, 08:30 AM
Junior Member
Question Won't Agitate but spins
By part #11 I assume you are referring to the Drive Bell. I replaced that item 4 years ago when a leaky tub needed a new seal kit. The Drive Bell is fine and so is the belt and bearing housing I replaced at the same time while I was in there.
The problem now seams to be electrical. The clicking sound appears to be a switch/overload/clutch and I need help identifying the source. I replaced the motor starter capacitor because it was cheap and easy to get at the local Graingers with no success. The motor appears to spin fine during the spin cycle which is the opposite direction from the start of the agitate cycle.
Are there schematics available so that I can test the motor switch and motor with my meter? Are there other ways to test these devices to determine the problem?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer Won't Agitate But It Spins FRANK66 Washer Repair 4 03-31-2008 07:43 AM
Washer spins instead of agitate garu Washer Repair 0 03-08-2008 12:06 PM
washer some what spins kent pratt Washer Repair 0 03-02-2008 03:18 PM
Tub Spins While Agitating icoetmartyp Washer Repair 0 12-07-2007 10:42 PM
Washer motor spins but will not agitate. jimmyr Washer Repair 1 09-19-2007 04:34 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
