| » Spray arms wobble; spray is weak |
Model Number: #66515634000 Brand: Kenmore Age: 5 - 10 years
I replaced the lower spray arm assembly seal a few months ago because the assembly was wobbling (the seal had come apart). The arm assembly still wobbled a bit, but output was okay and dishes were being cleaned properly. The wobble has gotten worse and now there is very little output from BOTH upper and lower spray arms. Any help would be appreciated!
Without being there it is hard to say what is wrong.
Remove the spray arm and check the spray arm it self and the upper and lower bearing/seals and check them for wear. Click on the pictire for better views. Upper Part number: AP3044851 Lower Part number: AP2920719 Spray Arm Part number: AP3044192 Could be the pump is not centered Part number: AP2908817 The following may also help https://secured.whirlpool.com/Servic...LE/4322455.pdf
__________________
| Display Modes | |
| No water in spray arms | chenke | Dishwasher Repair | 1 | 12-01-2009 09:11 AM |
| Spray arms don't work | esm | Dishwasher Repair | 1 | 09-15-2009 07:56 PM |
| low pressure to spray arms | degrub | Dishwasher Repair | 0 | 05-05-2009 07:37 PM |
| No water from spray arms | Junior020477 | Dishwasher Repair | 3 | 08-28-2008 03:09 AM |
| spray arms not turning | jon6180 | Dishwasher Repair | 1 | 01-17-2008 03:50 PM |
