Discuss
JennAir JDB6510AWP dishwasher won't fill
 in
Dishwasher Repair
Hello. My dishwasher won't fill. After looking around, I read that the water inlet valve is a common culprit,
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » JennAir JDB6510AWP dishwasher won't fill
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 05-09-2008, 02:37 PM
SPS SPS is offline
Junior Member
SPS is on a distinguished road
Default JennAir JDB6510AWP dishwasher won't fill
Model Number: JDB6510AWP   Brand: Jenn-Air   Age: 1 - 5 years
Hello. My dishwasher won't fill. After looking around, I read that the water inlet valve is a common culprit, so I ordered one from here and just put it on. The dishwasher still won't fill.
Water is definitely getting to the valve, and when I took the old one off, the line to the dishwasher had water in it, so it seems the valve was okay.
Thanks in advance
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 05-09-2008, 03:11 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
The first thing I would check is the float (#18 on the inner tub break down diagram). It should be in the bottom position and the water level control switch (under the float) should be closed in order to provide power to the water inlet valve.
Here are the break down diagrams for the Jenn Air dishwasher Model JDB6510AWP
__________________
Professional appliance repair services in Orange County, California.
  #3 (permalink)
Old 05-09-2008, 03:53 PM
ApplianceJunk's Avatar
ApplianceJunk ApplianceJunk is offline
Senior Expert
APP Volunteer
ApplianceJunk is on a distinguished road
Default
Some good advice from Gene.
Let us know what you find there.
  #4 (permalink)
Old 05-10-2008, 08:42 AM
SPS SPS is offline
Junior Member
Default
thanks. The float is down. The control switch is #19 in the diagram, correct? It appears to be closed. There's a white lever on the switch, on the right side of the lever a shaft from the float touches it. That end of the lever is down. That would make it closed, right?
  #5 (permalink)
Old 05-10-2008, 04:00 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Why not to check this switch for continuity? Also check for 120V coming to the water inlet valve while the timer calls for water.
__________________
  #6 (permalink)
Old 05-11-2008, 05:59 PM
SPS SPS is offline
Junior Member
Default
Quote:
Thanks for the reply. How do I do that?
  #7 (permalink)
Old 05-12-2008, 05:24 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The following article on our forum will explain in detail how to run a continuity test – How to check continuity with Ohmmeter.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thermador dishwasher won't fill Gumper Dishwasher Repair 0 05-07-2008 08:55 AM
Dishwasher won't fill cas Dishwasher Repair 1 04-16-2008 03:53 PM
Dishwasher will not fill with water linda alabama Dishwasher Repair 2 02-11-2008 05:59 PM
Dishwasher does not completely fill sammyv Dishwasher Repair 3 01-06-2008 10:01 PM
kenmore dishwasher won't fill freundin Dishwasher Repair 0 10-26-2007 04:54 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
