Discuss
Motor and Pump replacement
 in
Dishwasher Repair
The machine is stuck after it fills with water and won't pump out when I cancel the cycle. The
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Motor and Pump replacement
  #1 (permalink)
Old 05-08-2008, 07:53 PM
markbero markbero is offline
Junior Member
markbero is on a distinguished road
Default Motor and Pump replacement
Model Number: GU980SCGS2   Brand: Whirlpool   Age: 5 - 10 years
The machine is stuck after it fills with water and won't pump out when I cancel the cycle. The drain hose is filled with water. I'm handy enough with repairs, but I'm wondering if it's worth replacing the pump and motor on this model. Also if there are anything else I should get.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 05-09-2008, 04:58 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Remove the bottom panel and check if the pump was leaking and the motor is damaged.
If the motor itself is fine then the old pump can be rebuilt. If the motor is bad then the whole assembly has to be replaced and your decision should be based on the age and the condition of the dishwasher because of costly repair.
Here are the break down diagrams for the Whirlpool dishwasher Model GU980SCGS2
__________________
Professional appliance repair in Los Angeles, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
noise from motor or pump? sleach1 Dishwasher Repair 15 11-10-2008 04:35 PM
Circulation Pump Motor TOMPSI Dishwasher Repair 1 03-15-2008 10:34 PM
Whirlpool Pump Motor BEK46 Dishwasher Repair 3 03-03-2008 09:32 PM
pump/motor replacement willbill Dishwasher Repair 1 12-04-2007 11:01 PM
How can I seperate the motor from the pump? Sandman Washer Repair 3 08-29-2007 09:41 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
