I have a front loading GE washing machine that burned through a belt due to a jammed drum. I got the drum free and clear and a new belt, but I can't get the belt on the drum pulley and the drive shaft. I don't see an obvious way to adjust either the drive or the pulley to create enough slack to get the belt on. Any ideas?
