Discuss
How do I remover motor/pump/impeller
 in
Dishwasher Repair
How do I access and remove the ciruclation motor, pump, and impleller on a Bosch SHU6806UC/12 . I suspect a
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » How do I remover motor/pump/impeller
  #1 (permalink)
Old 02-10-2010, 03:41 PM
Junior Member
wmako is on a distinguished road
Default How do I remover motor/pump/impeller
Model Number: SHU6806UC/12   Brand: Bosch   Age: 5 - 10 years
How do I access and remove the ciruclation motor, pump, and impleller on a Bosch SHU6806UC/12 . I suspect a problem with one of them and would like to remove to check/inspect. I have removed the right side cover, and see everything. Do I need to somehow separate the tub from the base?
I came accross this post
See Photo - is this supposed to be there?
which talks about removing the pump on a SHU3336 UC/12 and even incudes a word document with instructions. Do these instructions also apply to my SHU6806UC/12? It looks similar.
Any help is greatly appreciated!
Ads By Google
Related Models
Whirlpool SHU70000
Whirlpool SHU70001
Whirlpool SHU70010
Whirlpool SHU70040
Whirlpool SHU70041
Whirlpool SHU70050
Whirlpool SHU70051
Whirlpool SHU70052
Whirlpool SHU75000
Whirlpool SHU75010
Whirlpool SHU75040
Whirlpool SHU75042
Whirlpool SHU80000
Whirlpool SHU80001
Whirlpool SHU80010
Whirlpool SHU80040
Whirlpool SHU80041
Whirlpool SHU80042
Bosch SHU8802 UC/12 (FD 8105-)
Bosch SHU8805 UC/12 (FD 8105-)
Bosch SHU8806 UC/12 (FD 8105-)
Bosch SHU8812 UC/12 (FD 8105-)
Bosch SHU8815 UC/12 (FD 8105-)
Bosch SHU8816 UC/12 (FD 8105-)
Whirlpool SHU90000
Whirlpool SHU90001
Whirlpool SHU90002
Whirlpool SHU90010
Whirlpool SHU90040
Whirlpool SHU90041
Whirlpool SHU90050
Whirlpool SHU99000
Whirlpool SHU99001
Bosch SHU9902 UC/06
Bosch SHU9902 UC/06 (FD 7905-7912)
Whirlpool SHU99040
Whirlpool SHU99041
Bosch SHU9905 UC/06
Bosch SHU9905 UC/06 (FD 7905-7912)
Whirlpool SHU99050
Whirlpool SHU99052
Whirlpool SHU99053
Bosch SHU9906 UC/06
Bosch SHU9906 UC/06 (FD 7905-7912)
Bosch SHU9912 UC/06
Bosch SHU9912 UC/06 (FD 7908-8002)
Bosch SHU9912 UC/11
Bosch SHU9912 UC/11 (FD 8002-8003)
Bosch SHU9912 UC/12
Bosch SHU9912 UC/12 (FD 8003-)
Bosch SHU9915 UC/06
Bosch SHU9915 UC/06 (FD 7908-8002)
Bosch SHU9915 UC/11
Bosch SHU9915 UC/11 (FD 8002-8003)
Bosch SHU9915 UC/12
Bosch SHU9915 UC/12 (FD 8003-)
Bosch SHU9916 UC/06
Bosch SHU9916 UC/06 (FD 7908-8002)
Bosch SHU9916 UC/11
Bosch SHU9916 UC/11 (FD 8002-8003)
Bosch SHU9916 UC/12
Bosch SHU9916 UC/12 (FD 8003-)
Bosch SHU9922 UC/12 (FD 8003-)
Bosch SHU9925 UC/12 (FD 8003-)
Bosch SHU9926 UC/12 (FD 8003-)
Bosch SHU9952 UC/12 (FD 8105 -)
Bosch SHU9955 UC/12 (FD 8105 -)
Bosch SHU9956 UC/12 (FD 8105 -)
Bosch SHV4303 UC/06
Bosch SHV4303 UC/06 (FD 7712-8002)
Bosch SHV4303 UC/11
Bosch SHV4303 UC/11 (FD 8002-8003)
Bosch SHV4303 UC/12
Bosch SHV4303 UC/12 (FD 8003-)
Bosch SHV46C03 UC/14 (FD 8211-)
Bosch SHV4803 UC/06
Bosch SHV4803 UC/06 (FD 7712-7812, 7905-7907)
Bosch SHV4803 UC/07
Bosch SHV4803 UC/07 (FD 7812-7905, 7907-8010)
Bosch SHV4803 UC/12
Bosch SHV4803 UC/12 (FD 8010-)
Bosch SHV66A03 UC/14 (FD 8301-)
Bosch SHV6803 UC/12 (FD 8105 -)
Bosch SHV99A03 UC/14 (FD 8212-)
Hoover SHWA2501A Washer - Top Loading
Hoover SHWA2501W Washer - Top Loading
Hoover SHWA2506A Washer - Top Loading
Hoover SHWA2506AT Washer - Top Loading
Hoover SHWA2506W Washer - Top Loading
Hoover SHWA2506WT Washer - Top Loading
Hoover SHWA2507A Washer - Top Loading
Hoover SHWA2507V Washer - Top Loading
Hoover SHWA2507W Washer - Top Loading
Bosch SHX33A02 UC/14 (FD 8211-)
Bosch SHX33A05 UC/14 (FD 8211-)
Bosch SHX33A06 UC/14 (FD 8211-)
Bosch SHX43E02 UC/14 (FD 8211-)
Bosch SHX43E05 UC/14 (FD 8211-)
Bosch SHX43E06 UC/14 (FD 8211-)
Bosch SHX46A02 UC/14 (FD 8211-)
Bosch SHX46A05 UC/14 (FD 8211-)
Bosch SHX46A06 UC/14 (FD 8211-)
Bosch SHX46A07 UC/14 (FD 8211-)
Bosch SHX46B02 UC/14 (FD 8211-)
Bosch SHX46B05 UC/14 (FD 8211-)
Bosch SHX46B06 UC/14 (FD 8211-)
Bosch SHX46B07 UC/14 (FD 8211-)
Bosch SHX56B02 UC/14 (FD 8211-)
Bosch SHX56B05 UC/14 (FD 8211-)
Bosch SHX56B06 UC/14 (FD 8211-)
Bosch SHX99B05 UC/14 (FD 8212-)
Bosch SHX99B06 UC/14 (FD 8212-)
Bosch SHY56A02 UC/14 (FD8301-)
Bosch SHY56A05 UC/14 (FD8301-)
Bosch SHY56A06 UC/14 (FD8301-)
Bosch SHY66C02 UC/14 (FD8301-)
Bosch SHY66C05 UC/14 (FD8301-)
Bosch SHY66C06 UC/14 (FD8301-)
Bosch SHY99A02 UC/14 (FD 8212-)
Bosch SHY99A05 UC/14 (FD 8212-)
  #2 (permalink)
Old 02-10-2010, 06:32 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Yes, you can use the same instructions. These models are very similar.
Here are the breakdown diagrams and Replacement parts for Bosch SHU6806 UC/12 (FD 8003-) | AppliancePartsPros.com
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 02-11-2010, 07:00 AM
Junior Member
Default
Thanks Gene,
It doesn't look like I have as much room to work from the side of the dishwasher as in the instructions. Are you sure I don't have to remove the base? Any one have insturctions for this?
  #4 (permalink)
Old 02-11-2010, 05:21 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
It is up to you. It would not do any bad if you remove the base on this side. I do not think you have to remove it completely.
__________________
  #5 (permalink)
Old 02-13-2010, 06:11 AM
Junior Member
Default
Thanks Gene - I removed two screws from the back, and four from the front. I laid the dw on it's back, and pulled the base away from the tub about 3-4 inches. This gave me enough room to pull off the motor for the circulation pump.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Pump impeller removal steveb123 Dishwasher Repair 4 07-14-2012 10:44 AM
How to access pump/impeller h2onxs Dishwasher Repair 1 10-08-2009 09:36 PM
How Do I Remove Impeller from Pump bseiter Dishwasher Repair 0 06-23-2009 10:20 PM
whirlpool pump impeller osage885 Dishwasher Repair 0 01-10-2009 02:26 PM
Noisy Pump, Impeller Now Broken? metman Dishwasher Repair 5 08-11-2007 05:09 PM
