Discuss
dishwasher wont rinse
 in
Dishwasher Repair
dishwasher will not do the heavy wash cycle or the rinse only cycle Ads By Google Related Models Whirlpool  MB1110SLQ
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » dishwasher wont rinse
  #1 (permalink)
Old 02-10-2010, 01:12 PM
Junior Member
kdraisey is on a distinguished road
Lightbulb dishwasher wont rinse
Model Number: maytag mdbtt60awq   Brand: Maytag   Age: Less than 1 year
Ads By Google
Related Models
Whirlpool MB1110SLQ MICROWAVE OVEN 1.1 CUBIC FOOT
Admiral MB1927PEHB REF - MAYTAG INT'L BOT MOUNT
Admiral MB1927PEHW REF - MAYTAG INT'L BOT MOUNT
Admiral MB2216PUAW REF - BOTTOM MOUNTS
Maytag MB2216PUAW11 REFRIGERATOR
Maytag MB2216PUAW2 REFRIGERATOR
Admiral MB2227PEHB REF - MAYTAG INT'L BOT MOUNT
Admiral MB2227PEHW REF - MAYTAG INT'L BOT MOUNT
Thermador MB245 MICROWAVE
General Electric MB536BB1 Electric range
Whirlpool MB7120XYB0 Microwaves*
Whirlpool MB7120XYB1 Microwaves*
General Electric MB757WB1 Electric range
Maytag MBB1952GRQ REF - BOTTOM MOUNTS
Maytag MBB1952GRW REF - BOTTOM MOUNTS
Maytag MBB1952HEB REF - BOTTOM MOUNTS
Maytag MBB1952HEB1 REFRIGERATOR
Maytag MBB1952HEB10 REFRIGERATOR
Maytag MBB1952HEQ REF - BOTTOM MOUNTS
Maytag MBB1952HEW REF - BOTTOM MOUNTS
Maytag MBB1952HEW14 REFRIGERATOR
Maytag MBB1952HEW5 REFRIGERATOR
Maytag MBB1953WEB0 REFRIGERATOR
Maytag MBB1953WEB1 REFRIGERATOR
Maytag MBB1953WEB2 REFRIGERATOR
Maytag MBB1953WEW0 REFRIGERATOR
Maytag MBB1953WEW1 REFRIGERATOR
Maytag MBB1953WEW2 REFRIGERATOR
Maytag MBB1953XEB0 REFRIGERATOR
Maytag MBB1953XEW0 REFRIGERATOR
Maytag MBB1954GEB REF - BOTTOM MOUNTS
Maytag MBB1954GEQ REF - BOTTOM MOUNTS
Maytag MBB1954GES REF - BOTTOM MOUNTS
Maytag MBB1954GEW REF - BOTTOM MOUNTS
Maytag MBB1954HEW REF - BOTTOM MOUNTS
Maytag MBB1956GEB REF - BOTTOM MOUNTS
Maytag MBB1956GEQ REF - BOTTOM MOUNTS
Maytag MBB1956GES REF - BOTTOM MOUNTS
Maytag MBB1956GEW REF - BOTTOM MOUNTS
Maytag MBB1956HEB REF - BOTTOM MOUNTS
Maytag MBB1956HEB14 REFRIGERATOR
Maytag MBB1956HEQ REF - BOTTOM MOUNTS
Maytag MBB1956HES REF - BOTTOM MOUNTS
Maytag MBB1956HEW REF - BOTTOM MOUNTS
Maytag MBB1956HEW14 REFRIGERATOR
Maytag MBB1957VEB1 REFRIGERATOR
Maytag MBB1957VEB10 REFRIGERATOR
Maytag MBB1957VEB2 REFRIGERATOR
Maytag MBB1957VEW1 REFRIGERATOR
Maytag MBB1957VEW10 REFRIGERATOR
Maytag MBB1957VEW2 REFRIGERATOR
Maytag MBB1957WEB0 REFRIGERATOR
Maytag MBB1957WEB1 REFRIGERATOR
Maytag MBB1957WEW0 REFRIGERATOR
Maytag MBB1957WEW1 REFRIGERATOR
Maytag MBB2254GEB REF - BOTTOM MOUNTS
Maytag MBB2254GEQ REF - BOTTOM MOUNTS
Maytag MBB2254GES REF - BOTTOM MOUNTS
Maytag MBB2254GEW REF - BOTTOM MOUNTS
Maytag MBB2256GEB REF - BOTTOM MOUNTS
Maytag MBB2256GEQ REF - BOTTOM MOUNTS
Maytag MBB2256GES REF - BOTTOM MOUNTS
Maytag MBB2256GEW REF - BOTTOM MOUNTS
Maytag MBCM24FWBS00 WINE CELLAR
Maytag MBF1952VEW1 REFRIGERATOR
Maytag MBF1956HEB REF - BOTTOM MOUNTS
Maytag MBF1956HEQ REF - BOTTOM MOUNTS
Maytag MBF1956HES REF - BOTTOM MOUNTS
Maytag MBF1956HEW REF - BOTTOM MOUNTS
Maytag MBF1956KEB REF - BOTTOM MOUNTS
Maytag MBF1956KEB11 REFRIGERATOR
Maytag MBF1956KEB2 REFRIGERATOR
Maytag MBF1956KEB3 REFRIGERATOR
Maytag MBF1956KEB4 REFRIGERATOR
Maytag MBF1956KEQ REF - BOTTOM MOUNTS
Maytag MBF1956KEQ11 REFRIGERATOR
Maytag MBF1956KEQ2 REFRIGERATOR
Maytag MBF1956KEQ3 REFRIGERATOR
Maytag MBF1956KEQ4 REFRIGERATOR
Maytag MBF1956KEW REF - BOTTOM MOUNTS
Maytag MBF1956KEW11 REFRIGERATOR
Maytag MBF1956KEW2 REFRIGERATOR
Maytag MBF1956KEW3 REFRIGERATOR
Maytag MBF1956KEW4 REFRIGERATOR
Maytag MBF1958WEB0 REFRIGERATOR
Maytag MBF1958WEB1 REFRIGERATOR
Maytag MBF1958WES0 REFRIGERATOR
Maytag MBF1958WES1 REFRIGERATOR
Maytag MBF1958WES2 REFRIGERATOR
Maytag MBF1958WES3 REFRIGERATOR
Maytag MBF1958WEW0 REFRIGERATOR
Maytag MBF1958WEW1 REFRIGERATOR
Maytag MBF1958XEB0 REFRIGERATOR
Maytag MBF1958XEQ0 REFRIGERATOR
Maytag MBF1958XES0 REFRIGERATOR
Maytag MBF1958XEW0 REFRIGERATOR
Maytag MBF2254HEB REF - BOTTOM MOUNTS
Maytag MBF2254HEB14 REFRIGERATOR
Maytag MBF2254HEB4 REFRIGERATOR
Maytag MBF2254HEQ REF - BOTTOM MOUNTS
Maytag MBF2254HEQ14 REFRIGERATOR
Maytag MBF2254HEQ4 REFRIGERATOR
Maytag MBF2254HES REF - BOTTOM MOUNTS
Maytag MBF2254HEW REF - BOTTOM MOUNTS
Maytag MBF2254HEW14 REFRIGERATOR
Maytag MBF2254HEW4 REFRIGERATOR
Maytag MBF2255KEB REF - BOTTOM MOUNTS
Maytag MBF2255KEB11 REFRIGERATOR
Maytag MBF2255KEQ REF - BOTTOM MOUNTS
Maytag MBF2255KEQ11 REFRIGERATOR
Maytag MBF2255KEW REF - BOTTOM MOUNTS
Maytag MBF2255KEW11 REFRIGERATOR
Maytag MBF2256HEB REF - BOTTOM MOUNTS
Maytag MBF2256HEQ REF - BOTTOM MOUNTS
Maytag MBF2256HES REF - BOTTOM MOUNTS
Maytag MBF2256HEW REF - BOTTOM MOUNTS
Maytag MBF2256KEB REF - BOTTOM MOUNTS
Maytag MBF2256KEB11 REFRIGERATOR
Maytag MBF2256KEB2 REFRIGERATOR
Maytag MBF2256KEB3 REFRIGERATOR
  #2 (permalink)
Old 02-11-2010, 03:16 AM
Senior Expert
APP Volunteer
denman is a glorious beacon of light
Default
Replacement parts for MAYTAG MDBTT60AWQ Dishwasher - Undercounter | AppliancePartsPros.com
Here is a tech sheet
http://www.servicematters.com/docs/w...0W10179503.pdf
Try the diagnostics.
Since only 2 buttons do not work and it looks like there is no common connection which only involves 2 switches, it sounds like the control board is gone.
I would still check the control panel (keypad) switches with a meter.
Also try the cleaning procedure.
If the switches check out OK and the cleaning does nothing then odds are the control board is gone.
Connector Cleaning / Checking
Unplug the unit
Open it up
Remove the ribbon cable from the keypad to the control board at the control board.
Clean the edge connector.
If it is the type where there is not a connector just the insulation is removed, it can be cleaned with a pencil eraser. Do not use an ink eraser as it is too abrasive.
Check the tracks in the ribbon cable for hairline cracks. A magnifying glass helps here.
Would not hurt to clean the connector on the board. Use electronics contact cleaner or isopropyl alcohol and a tooth brush. Be gentle and do not reconnect till all the solvent evaporates.
Reconnect everything and give it a try.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool dishwasher wont wash or rinse, does drain ppotman Dishwasher Repair 5 01-13-2010 09:59 AM
dishwasher only hums on rinse cycle, does'nt rinse chris67 Dishwasher Repair 1 10-25-2009 05:01 AM
Drum wont spin during rinse cycle waldie38 Washer Repair 1 09-30-2009 04:10 PM
GE washer wont rinse or spin. Irish25 Washer Repair 1 05-17-2009 03:35 PM
washer wont rinse or spin melinda123 Washer Repair 0 03-24-2009 09:44 PM
