Discuss
Dishwasher inconsistantly draining
 in
Dishwasher Repair
I have a dishwasher that seems to drain just fine on some days and not drain at all on others..what's
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Dishwasher inconsistantly draining
  #1 (permalink)
Old 02-10-2010, 08:16 AM
Junior Member
Dorothy Pratt is on a distinguished road
Cool Dishwasher inconsistantly draining
Model Number: 363.15655891   Brand: Kenmore   Age: 1 - 5 years
I have a dishwasher that seems to drain just fine on some days and not drain at all on others..what's up with this? I have checked the drain flow and it's clear and I can watch it drain nicely right into the garbage disposial....this unit does not have a breather on it.....could this be part of the issue?
Ads By Google
Related Models
Kenmore 363.3042992  24" GAS BUILT-IN OVEN
Kenmore 363.33355590  KENMORE 30" COUNTER UNIT
Kenmore 363.33356590  KENMORE 30" COUNTER UNIT
Kenmore 363.33359590  KENMORE 30" COUNTER UNIT
Kenmore 363.356630  GAS RANGE
Kenmore 363.37400790  REFRIGERATOR
Kenmore 363.37400791  REFRIGERATOR
Kenmore 363.37400792  REFRIGERATOR
Kenmore 363.37401790  Top-Mount
Kenmore 363.37401791  REFRIGERATOR
Kenmore 363.37401792  REFRIGERATOR
Kenmore 363.37408790  REFRIGERATOR
Kenmore 363.37408791  REFRIGERATOR
Kenmore 363.37408792  REFRIGERATOR
Kenmore 363.37409790  REFRIGERATOR
Kenmore 363.37409791  REFRIGERATOR
Kenmore 363.37409792  REFRIGERATOR
Kenmore 363.37450791  REFRIGERATOR
Kenmore 363.37450792  REFRIGERATOR
Kenmore 363.37450890  REFRIGERATOR
Kenmore 363.37451791  REFRIGERATOR
Kenmore 363.37451792  REFRIGERATOR
Kenmore 363.37451890  REFRIGERATOR
Kenmore 363.37458791  REFRIGERATOR
Kenmore 363.37458792  REFRIGERATOR
Kenmore 363.37458890  REFRIGERATOR
Kenmore 363.37459791  REFRIGERATOR
Kenmore 363.37459792  REFRIGERATOR
Kenmore 363.37459890  REFRIGERATOR
Kenmore 363.38450890  REFRIGERATOR
Kenmore 363.38451890  REFRIGERATOR
Kenmore 363.38458890  REFRIGERATOR
Kenmore 363.38459890  REFRIGERATOR
Kenmore 363.39400990  REFRIGERATOR
Kenmore 363.39400991  REFRIGERATOR
Kenmore 363.39401990  REFRIGERATOR
Kenmore 363.39401991  REFRIGERATOR
Kenmore 363.42482200  ELECTRIC RANGE
Kenmore 363.42484200  ELECTRIC RANGE
Kenmore 363.42489200  ELECTRIC RANGE
Kenmore 363.4272790  MODULAR COOKTOP
Kenmore 363.43482200  ELECTRIC RANGE
Kenmore 363.43484200  ELECTRIC RANGE
Kenmore 363.43489200  ELECTRIC RANGE
Kenmore 363.4672994  30" RADIANT SLIDE IN RANGE
Kenmore 363.46964001  REFRIGERATOR
Kenmore 363.46964009  REFRIGERATOR
Kenmore 363.4803592  DOUBLE CONVECTION BUILT-IN OVEN
Kenmore 363.4803993  DOUBLE CONVECTION BUILT-IN OVEN
Kenmore 363.48042890  REFRIGERATOR
Kenmore 363.48042891  REFRIGERATOR
Kenmore 363.48042892  REFRIGERATOR
Kenmore 363.48042893  REFRIGERATOR
Kenmore 363.48042894  REFRIGERATOR
Kenmore 363.48042896  REFRIGERATOR
Kenmore 363.48042897  REFRIGERATOR
Kenmore 363.48047890  REFRIGERATOR
Kenmore 363.48047891  REFRIGERATOR
Kenmore 363.48047892  REFRIGERATOR
Kenmore 363.48047893  REFRIGERATOR
Kenmore 363.48047894  REFRIGERATOR
Kenmore 363.48047896  REFRIGERATOR
Kenmore 363.48047897  REFRIGERATOR
Kenmore 363.48252890  REFRIGERATOR
Kenmore 363.48252891  REFRIGERATOR
Kenmore 363.48252892  REFRIGERATOR
Kenmore 363.48252893  REFRIGERATOR
Kenmore 363.48252894  REFRIGERATOR
Kenmore 363.48252896  REFRIGERATOR
Kenmore 363.48252897  REFRIGERATOR
Kenmore 363.48257890  REFRIGERATOR
Kenmore 363.48257891  REFRIGERATOR
Kenmore 363.48257892  REFRIGERATOR
Kenmore 363.48257893  REFRIGERATOR
Kenmore 363.48257894  REFRIGERATOR
Kenmore 363.48257896  REFRIGERATOR
Kenmore 363.48257897  REFRIGERATOR
Kenmore 363.4832594  27" ELECTRIC BUILT-IN DOUBLE OVEN
Kenmore 363.4832995  27" ELECTRIC BUILT-IN DOUBLE OVEN
Kenmore 363.4842592  ELEC BUILT-IN DBL OVEN
Kenmore 363.4842594  ELECTRIC BUILT-IN DOUBLE OVEN
Kenmore 363.4842992  ELEC BUILT-IN DBL OVEN
Kenmore 363.4842995  ELECTRIC BUILT-IN DOUBLE OVEN
Kenmore 363.4998731  RADIANT MODULE
Kenmore 363.50221000  REFRIGERATOR
Kenmore 363.50222000  REFRIGERATOR
Kenmore 363.50227000  REFRIGERATOR
Kenmore 363.50232000  REFRIGERATOR
Kenmore 363.50237000  REFRIGERATOR
Kenmore 363.50242000  REFRIGERATOR
Kenmore 363.50247000  REFRIGERATOR
Kenmore 363.50622000  REFRIGERATOR
Kenmore 363.50627000  REFRIGERATOR
Kenmore 363.57552790  SIDE BY SIDE
Kenmore 363.57552791  SIDE BY SIDE
Kenmore 363.57557790  SIDE BY SIDE
Kenmore 363.57557791  SIDE BY SIDE
Kenmore 363.58042890  REFRIGERATOR
Kenmore 363.58042891  REFRIGERATOR
Kenmore 363.58042892  REFRIGERATOR
Kenmore 363.58042893  REFRIGERATOR
Kenmore 363.58042894  REFRIGERATOR
Kenmore 363.58042896  REFRIGERATOR
Kenmore 363.58042897  REFRIGERATOR
Kenmore 363.58047890  REFRIGERATOR
Kenmore 363.58047891  REFRIGERATOR
Kenmore 363.58047892  REFRIGERATOR
Kenmore 363.58047893  REFRIGERATOR
Kenmore 363.58047894  REFRIGERATOR
Kenmore 363.58047896  REFRIGERATOR
Kenmore 363.58047897  REFRIGERATOR
Kenmore 363.58062890  REFRIGERATOR
Kenmore 363.58062891  REFRIGERATOR
Kenmore 363.58062892  REFRIGERATOR
Kenmore 363.58062893  REFRIGERATOR
Kenmore 363.58062894  REFRIGERATOR
Kenmore 363.58062896  REFRIGERATOR
Kenmore 363.58062897  REFRIGERATOR
Kenmore 363.58067890  REFRIGERATOR
Kenmore 363.58067891  REFRIGERATOR
  #2 (permalink)
Old 02-11-2010, 02:00 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
I cannot find any info on the given model number.
The 363. does tell me it is actually a GE unit.
Most GE's use the same pump and some also use a separate drain pump.
I am assuming you do not have a separate drain pump.
Does it drain out any water?
They usually fill to just under the heating element.
If it does not drain at all during the cycle, it should not fill at all after the second fill as this would have tripped the overflow float/switch which disconnects the water valve.
These units usually leave about a 1/4 inch of water above the sump. The pumps do not like to run when dry, they will burn out the seals.
I have checked the drain flow and it's clear and I can watch it drain nicely right into the garbage disposal....this unit does not have a breather on it.....could this be part of the issue?
Probably not as long as the drain hose is looped up about 12 to 18 inches above where it enters the house plumbing. All the breather (air gap) does is stop the it from siphoning water back into the unit from the house plumbing.
The way your drain works is that the pump has a solenoid (left hand side of pump assembly), at the start of a drain cycle this solenoid is pulled down. It moves a flapper valve in the pump, from the wash to the drain position. The water is then directed out the drain instead of up to the wash arms. Note that it is only activated for about 10 seconds and then the water pressure holds the flapper in the drain position till the unit is empty. The spring then pulls the solenoid back up to the wash position.
Remove the kick plate and manually move the solenoid arm/plunger to see if it is free. Sometimes the timer contacts for the solenoid can stick closed, this powers the solenoid for more than 10 seconds. It overheats and melts the inside plastic so the solenoid starts sticking.
Remove the sump cover (center, bottom of tub) and check the sump for debris and that there is nothing wrapped around the chopper. Take note how the inside piece is installed, put it back wrong and the chopper will eat it. Also be careful there is often broken glass in the sump.
Some units have what is called a Piston & Nut, this is if your unit has a filter screen at the back/bottom of the tub. This should close when in drain or some water is directed back into the tub instead of out the drain. Remove the rear filter/cover and check the Piston & Nut. It unscrews. Normally though when it fails the unit still pumps out some of the water.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dishwasher Not Draining Cprig Dishwasher Repair 0 01-27-2010 10:49 AM
Dishwasher not draining Tonyb571 Dishwasher Repair 5 09-08-2009 06:02 AM
GE dishwasher not draining jharlow2 Dishwasher Repair 1 06-08-2009 10:38 AM
Dishwasher not draining Mayobeach Dishwasher Repair 7 03-12-2009 11:04 AM
Dishwasher not draining scott3151 Dishwasher Repair 5 10-03-2008 02:17 PM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
