Discuss
Maytag Washer not cleaning well
 in
Dishwasher Repair
Hi, My Maytag MDB7160AWB washer started not cleaning very well a few weeks ago, food would be left on dishes,
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Maytag Washer not cleaning well
  #1 (permalink)
Old 05-06-2008, 05:37 AM
themccubbins themccubbins is offline
Junior Member
themccubbins is on a distinguished road
Default Maytag Washer not cleaning well
Model Number: MDB7160AWB   Brand: Maytag   Age: 1 - 5 years
My Maytag MDB7160AWB washer started not cleaning very well a few weeks ago, food would be left on dishes, etc. I confirmed the water is hot, water gets in to the washer, it sounds like it is filling, running and draining, but the dishes are still dirty. I did test the resistance of the inlet valve and it's not an open circuit but it is reading 1000 ohms. Is that the problem then, or is that normal for that inlet valve?
Thanks.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 05-06-2008, 05:07 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Open the door during the wash cycle and check the water level and see if both spray arms are rotating.
Post your findings.
Here are the break down diagrams for the Maytag dishwasher Model MDB7160AWB
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 05-08-2008, 11:20 PM
Junior Member
Default
The water level seems to be ok and the arms seem to be rotating, but they stop spinning before i can even look inside. I know they are rotating just because they are in a different place every time I open the door.
EDIT: Actually, now that I am checking further along in the cycle, it seems like the water stops getting pumped around and the arms stop moving. It's making noise but when I open the door there's no water coming out of the arms.
Chris
  #4 (permalink)
Old 05-09-2008, 05:57 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Chris,
Sounds like there is a problem with the wash pump. If the dishwasher is less than five years old - it is still under the limited manufacturer warranty and it's better if you call Maytag for service.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
maytag washer Tracy Ahana Washer Repair 1 03-24-2008 06:47 PM
maytag washer catwood Washer Repair 1 01-12-2008 02:38 AM
maytag washer roquescraig Washer Repair 0 11-13-2007 06:32 AM
maytag washer jerman Washer Repair 1 09-27-2007 03:29 AM
self-cleaning oven got so hot when cleaning that it melted the surrounding cabinet do anne Oven Repair (including Ranges and Cooktops) 0 09-21-2007 07:30 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
