Discuss
Bosch Dishwasher Not Draining
 in
Dishwasher Repair
I have a Bosch Dishwasher (Model SHU3035UC). The dishwasher won’t drain. There is standing water in the bottom of the
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Bosch Dishwasher Not Draining
  #1 (permalink)
Old 02-09-2010, 05:51 AM
Junior Member
adam22 is on a distinguished road
Default Bosch Dishwasher Not Draining
Model Number: SHU3035UC   Brand: Bosch   Age: 5 - 10 years
I have a Bosch Dishwasher (Model SHU3035UC). The dishwasher won’t drain. There is standing water in the bottom of the unit. I can actually hear the water circulating through the arms when the dishwasher is in that part of the cycle, but when it’s in the part of the cycle where it wants to pump the water out to the sink, I hear a humming noise, and nothing happens. The humming is softer that I’ve heard before when the unit is actually successfully pumping the water out.
I’m willing to try to change out some parts, and I’m willing to change a few parts just to be sure I’m covering my bases. The problem is, I don’t know what to change.
This may or may not be related, but this unit has also had two other problems: it has the dial type cycle selector/timer, and that has occasionally gotten stuck so the dishwasher doesn’t finish its cycle. Also, this dishwasher has leaked out the front door occasionally (but not recently). I bought the unit in 2003 or so, and I would throw in the towel if it didn’t do such a nice job on the dishes.
Thanks for any help!
Adam
Ads By Google
Related Models
Bosch SHU3036 UC/06 (FD 7908-8002)
Bosch SHU3036 UC/11 (FD 8002-8003)
Bosch SHU3036 UC/12 (FD 8003-)
Bosch SHU3132 UC/12 (FD 8105-)
Bosch SHU3135 UC/12 (FD 8105-)
Bosch SHU3136 UC/12 (FD 8105-)
Bosch SHU3302 UC/06 (FD 7902-8003)
Bosch SHU3302 UC/11 (FD 8003-8003)
Bosch SHU3302 UC/12 (FD 8003 -)
Bosch SHU3305 UC/06 (FD 7902-8003)
Bosch SHU3305 UC/11 (FD 8003-8003)
Bosch SHU3305 UC/12 (FD 8003 -)
Bosch SHU3306 UC/06 (FD 7902-8003)
Bosch SHU3306 UC/11 (FD 8003-8003)
Bosch SHU3306 UC/12 (FD 8003 -)
Bosch SHU3307 UC/12 (FD 8005 -)
Bosch SHU3322 UC/06
Bosch SHU3322 UC/11
Bosch SHU3322 UC/12
Bosch SHU3322 UC/12 (FD 8003-)
Bosch SHU3326 UC/06
Bosch SHU3326 UC/11
Bosch SHU3326 UC/12
Bosch SHU3326 UC/12 (FD 8003-)
Bosch SHU3336 UC/06
Bosch SHU3336 UC/11
Bosch SHU3336 UC/12
Bosch SHU3336 UC/12 (FD 8003-)
Bosch SHU33A02 UC/14 (FD 8211-)
Bosch SHU33A06 UC/14 (FD 8211-)
Bosch SHU33AC02 UC/14
Bosch SHU33AC06 UC/14
Whirlpool SHU40000
Whirlpool SHU40010
Whirlpool SHU40011
Bosch SHU4002 UC/06
Whirlpool SHU40040
Whirlpool SHU40041
Bosch SHU4006 UC/06
Bosch SHU4016 UC/06
Bosch SHU4022 UC/06
Bosch SHU4026 UC/06
Bosch SHU4036 UC/06
Bosch SHU4302 UC/06 (FD 7705-7912)
Bosch SHU4302 UC/11 (FD 8001-8003)
Bosch SHU4302 UC/12 (FD 8003-)
Bosch SHU4306 UC/06 (FD 7705-7912)
Bosch SHU4306 UC/11 (FD 8001-8003)
Bosch SHU4306 UC/12 (FD 8003-)
Bosch SHU4312 UC/06 (FD 7701-7912)
Bosch SHU4312 UC/11 (FD 8001-8003)
Bosch SHU4312 UC/12 (FD 8003-)
Bosch SHU4316 UC/06
Bosch SHU4316 UC/11
Bosch SHU4316 UC/12
Bosch SHU4322 UC/12
Bosch SHU4322 UC/12 (FD 8003-)
Bosch SHU4326 UC/12
Bosch SHU4326 UC/12 (FD 8003-)
Bosch SHU43C02 UC/14 (FD 8211-)
Bosch SHU43C05 UC/14 (FD 8211-)
Bosch SHU43C06 UC/14 (FD 8211-)
Bosch SHU43C07 UC/14 (FD 8211-)
Bosch SHU43E02 UC/14 (FD 8211-)
Bosch SHU43E05 UC/14 (FD 8211-)
Bosch SHU43E06 UC/14 (FD 8211-)
Bosch SHU43E07 UC/14 (FD 8211-)
Whirlpool SHU45010
Whirlpool SHU45020
Whirlpool SHU50000
Whirlpool SHU50001
Whirlpool SHU50002
Whirlpool SHU50010
Whirlpool SHU50040
Whirlpool SHU50041
Whirlpool SHU50043
Bosch SHU5302 UC/06 (FD 7705-7912)
Bosch SHU5302 UC/11 (FD 8001-8003)
Bosch SHU5302 UC/12 (FD 8003-)
Bosch SHU5304 UC/06 (FD 7705-7912)
Bosch SHU5304 UC/11 (FD 8001-8003)
Bosch SHU5304 UC/12 (FD 8003-)
Bosch SHU5305 UC/06 (FD 7705-7912)
Bosch SHU5305 UC/11 (FD 8001-8003)
Bosch SHU5305 UC/12 (FD 8003-)
Bosch SHU5306 UC/06 (FD 7705-7912)
Bosch SHU5306 UC/11 (FD 8001-8003)
Bosch SHU5306 UC/12 (FD 8003-)
Bosch SHU5307 UC/12 (FD 8003-)
Bosch SHU5312 UC/06
Bosch SHU5312 UC/11
Bosch SHU5312 UC/12
Bosch SHU5314 UC/06
Bosch SHU5314 UC/11
Bosch SHU5314 UC/12
Bosch SHU5315 UC/06
Bosch SHU5315 UC/06 (FD 7705-7912)
Bosch SHU5315 UC/11
Bosch SHU5315 UC/11 (FD 8001-8003)
Bosch SHU5315 UC/12
Bosch SHU5315 UC/12 (FD 8003-)
Bosch SHU5316 UC/06
Bosch SHU5316 UC/11
Bosch SHU5316 UC/12
Bosch SHU5317 UC/12
Bosch SHU53A02 UC/14 (FD 8211-)
Bosch SHU53A05 UC/14 (FD 8211-)
Bosch SHU53A06 UC/14 (FD 8211-)
Bosch SHU53E02 UC/14 (FD 8211-)
Bosch SHU53E05 UC/14 (FD 8211-)
Bosch SHU53E06 UC/14 (FD 8211-)
Whirlpool SHU55000
Whirlpool SHU55010
Whirlpool SHU55040
Whirlpool SHU55041
Whirlpool SHU55042
Whirlpool SHU60010
Whirlpool SHU60011
Whirlpool SHU60020
Bosch SHU66C02 UC/14 (FD 8211-)
  #2 (permalink)
Old 02-12-2010, 06:54 AM
Frank / APP Team's Avatar
Senior Expert
Frank / APP Team is on a distinguished road
Default
Adam
If you're hearing a humming noise when it should be draining it sounds like you're getting power to the drain pump. Probably need to look at the pump and see if something may be stuck in it. If nothing is blocking it, then maybe it is locked up and just humming not actually running. Don't overlook something blocking the drain hose from the DW to wherever it goes into your plumbing.
Below is a pic of the drain pump.
Part number: AP2802385
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 02-13-2010, 04:08 AM
Senior Expert
APP Volunteer
richappy is a name known to all
Default
I woul first remove the drain hose from the drain fitting, stick it in a bucket and, run the dishwasher, if you are lucky any debree will flush out.
If no go, you will need to pull the dishwasher, remove the bottom panel, and stich 115 volts to the pump, if no go, order the pump.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
bosch dishwasher not draining after cycle (more than usual) mpmurphy Dishwasher Repair 1 11-04-2009 07:44 AM
Bosch Dishwasher Not Draining. Makes Buzzing Noise. fredk99 Dishwasher Repair 2 09-23-2009 12:32 PM
Bosch SHU8802 Stuck Draining RyanE Dishwasher Repair 10 05-02-2009 03:14 AM
Bosch Exxcel - Not Draining Bootpolish Dishwasher Repair 0 01-16-2009 01:46 PM
Non-draining Bosch Dishwasher R.DREWEK Dishwasher Repair 1 11-19-2008 03:52 PM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
