Discuss
Hotpoint will not fill
 in
Dishwasher Repair
I replaced the water inlet valve and cleaned the float mechanism inside the tub. I disconected the float switch and
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Hotpoint will not fill
  #1 (permalink)
Old 05-02-2008, 12:34 PM
abrzrkr abrzrkr is offline
Junior Member
abrzrkr is on a distinguished road
Default Hotpoint will not fill
Model Number: HDA2220Z02BB   Brand: Hotpoint   Age: 5 - 10 years
I replaced the water inlet valve and cleaned the float mechanism inside the tub. I disconected the float switch and held the wires together and it still will not fill. When I replaced the water inlet valve I tested the water supply line and it is live. Does any one have any ideas? Thanks for your help.
Seth
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 05-02-2008, 03:11 PM
Junior Member
Default
Anyone have any clue what the problem could be? I'm at a loss here.
  #3 (permalink)
Old 05-02-2008, 09:28 PM
misterfixall misterfixall is offline
Senior Expert
APP Volunteer
misterfixall is on a distinguished road
Default
is there water coming to valve from water supply
__________________
  #4 (permalink)
Old 05-03-2008, 08:17 AM
Junior Member
Default
Yes there is water at the fill valve. Is there a brain or a computer that would prevent the fill valve from doing it's job?
  #5 (permalink)
Old 05-03-2008, 08:57 AM
Senior Expert
APP Volunteer
Default
if your not getting 110 volts to float switch it well maybe control board .p.s is d/w doing anything ,any sign of life ,sounds ,lights,etc
__________________
  #6 (permalink)
Old 05-03-2008, 11:28 PM
Junior Member
Default
The machine starts and there is noise and action but no water. Could that be a malfunction with the control panel?
  #7 (permalink)
Old 05-04-2008, 04:54 AM
Senior Expert
APP Volunteer
Default
are you getting 110 volts to float switch? if not it sound like board ,check to see power from board also.if there is power . check for continuity in wire from board to fl. switch, to see there is no break in wire.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
hotpoint range perry8590 Oven Repair (including Ranges and Cooktops) 1 03-26-2008 04:06 PM
Hotpoint Dishwasher vance Dishwasher Repair 1 02-28-2008 03:34 PM
Hotpoint nightmare Fridgecrapmagnet Refrigerator & Freezer Repair 7 02-25-2008 12:29 PM
Hotpoint dishwasher Brian Ramsden Dishwasher Repair 1 02-17-2008 04:05 AM
No heat in hotpoint history Dryer Repair 0 01-12-2008 03:48 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
