Discuss
Whirlpool Quiet Partner II Does Not Run
 in
Dishwasher Repair
Got part for drain problem and got that part solved. Still having trouble with heating part. Heating element tested at
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Whirlpool Quiet Partner II Does Not Run
  #31 (permalink)
Old 11-02-2012, 01:52 PM
Junior Member
ppeek is on a distinguished road
Default
Got part for drain problem and got that part solved. Still having trouble with heating part. Heating element tested at 10.8 ohms. Hi limit .01. Could water temp from source cause this problem we changed from gas water heater to Electric and that is when the problem started. We have been having problems with not enough hot water. I checked the thermostat and it is set at 115 degrees.
Ads By Google
  #32 (permalink)
Old 11-02-2012, 05:23 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Originally Posted by ppeek View Post
...Could water temp from source cause this problem we changed from gas water heater to Electric and that is when the problem started. We have been having problems with not enough hot water...
It is very possible. Incoming water temperature per instructions from any dishwashers manufacturers should be about 120°F.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #33 (permalink)
Old 02-19-2013, 12:15 PM
Junior Member
sarigal is on a distinguished road
Default Whirpool Quiet Partner V Issue
Hi saw this thread and tried to do the reset, it worked but when I go to run the washer regularly the blinking starts again. I am not a technical person, is there something else I can do to try to get this working???
  #34 (permalink)
Old 02-19-2013, 03:02 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
What is the complete model number of the dishwasher?
__________________
  #35 (permalink)
Old 02-19-2013, 03:04 PM
Junior Member
Default
Hi Gene, the model number is...
GU2800XTVS0
  #36 (permalink)
Old 02-19-2013, 03:14 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
There are three parts in the heating circuit. They are: the heater, the hi-limit thermostat (under the dishwasher) and the control board.
Check the heater and the hi-limit thermostat for continuity. If any of them is open, it has to be replaced.
If there is nothing wrong, replace the control board.
- The heater Part number: W10134009
- The hi-limit thermostat Part number: 661566
Part number: 661566
- The control board Part number: W10285178
Here are the breakdown diagrams and Parts for Whirlpool GU2800XTVS0 Dishwasher - AppliancePartsPros.com
__________________
  #37 (permalink)
Old 03-27-2013, 02:11 PM
Banned
ryguy722 is on a distinguished road
Default Clean Light Blinking 7x
I have a DU1055XTPS3 (Whirlpool Quiet Partner 1) from 2004 or 2005 and the Clean Light blinks 7x. I tried the "Normal - Heat Dry" sequence 4x and that seemed to reset the dishwasher to no lights blinking. I then ran a normal cycle and it seemed to run alright. After it ran on Normal Cycle, the clean light started blinking 7x again.
As a side note, I replaced the fill sensor about 2 years ago and that seems to be functioning alright as I listened and timed the fill to exactly 100 seconds. I checked the water level and it was just barely under the filament, not submerged. Do I need to level the dishwasher better?
Do I need to check the hi limit thermostat or heater element? If so, how do I go about checking for continuity on those parts... from one end of the filament to the other? Please advise next steps.
Thanks!
  #38 (permalink)
Old 03-27-2013, 09:37 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Yes, you do need to check the heating element and the hi-limit thermostat for continuity.
You have to remove the wires from the tested part terminals prior to the test.
The part numbers for the heater and the hi-limit thermostat are the same as posted in the previous post.
- The control board Part number: 8564547
Here are the breakdown diagrams and Parts for Whirlpool DU1055XTPS3 Dishwasher - AppliancePartsPros.com
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Quiet Partner II cocodon Dishwasher Repair 1 01-28-2010 04:30 AM
Whirlpool Quiet Partner II Gallexy Dishwasher Repair 3 11-18-2009 07:58 AM
Whirlpool Quiet Partner I Fran Button Dishwasher Repair 0 06-12-2009 01:04 PM
Whirlpool Quiet Partner III tdonovan Dishwasher Repair 6 03-16-2009 05:02 PM
Whirlpool Quiet Partner III Lenwann Dishwasher Repair 2 03-08-2009 12:12 PM
