Discuss
Dishwasher Motor Hums
 in
Dishwasher Repair
I have a 1989 vintage Maytag Dishwasher. For some time now, the soap dispenser door would not open on its
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Dishwasher Motor Hums
  #1 (permalink)
Old 05-01-2008, 10:13 AM
teaspoon teaspoon is offline
Junior Member
teaspoon is on a distinguished road
Default Dishwasher Motor Hums
Brand: Maytag   Age: More than 10 years
I have a 1989 vintage Maytag Dishwasher. For some time now, the soap dispenser door would not open on its own. Therefore, we open the door to the dishwasher and manually open the door to the dispenser. We have done it that way for sometime without issue. Tonight, the dishwasher started up normally but after we opened the door to release the soap and closed the dishwaser door, the unit quit working. We can hear the motor hum and watch the timer advance as it should through each cycle but nothing happens during any of the cycles (except for the humming of the motor). Since the wash cycle was initiated at the time, water is still in the unit. Any help you can offer would be appreciated. Thanks.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 05-01-2008, 07:09 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Most likely the problem is a bad pump and/or motor. For more accurate advise we need the complete model number of the dishwasher.
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 05-01-2008, 08:52 PM
Junior Member
Default
Gene,
Thanks for the reply. The Model # is WU202. Depending on the extent of the problem as you see it, I am also wondering if I should consider replacing this unit and credit it with a "job well done"?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Hums... A New motor handiman43 Washer Repair 0 02-13-2008 01:36 PM
Dryer motor hums & will not turn mmaynard Dryer Repair 1 01-29-2008 12:53 PM
Amana fills with H20 then motor hums and smokes jpstelly Washer Repair 3 01-28-2008 08:59 PM
Gas dryer motor hums but won't start nonqual Dryer Repair 5 12-27-2007 05:40 AM
Washer motor hums, but won't drain, agitate or spin redwood646 Washer Repair 2 09-11-2007 08:39 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
