| » Dishwasher not draining properly |
Model Number: FDB2810LDC1 Brand: Frigidaire Age: 1 - 5 years
Hi all,
I ran the dishwasher overnight and woke up to water in the base of the tub. I sucked out that water and did a rinse only cycle. This delivered the same results. I pulled the front base panel and removed the pump. Is there any way to test the pump to see if it is operational? Also my father told me to check the drain solenoid but according to the schematic the is no solinoid on ths model. The pump sounds like it is running but makes a buzzing sound. Thank You Ads By Google Related Models |
UPDATE!
I discovered a clog in the drain hose to the disposal. One problem fixed. Discovered 2 leaks in the process. 1) Heating element where it penetrates the tub (loose bolt) 2) Base of the door. Still trying to figure this one out. |
| Display Modes | |
| Dishwasher Does Not Drain Properly | redsky | Dishwasher Repair | 0 | 10-09-2009 01:08 PM |
| washing machine not draining properly | htuttle | Washer Repair | 1 | 05-31-2009 12:01 PM |
| Dishwasher not draining | scott3151 | Dishwasher Repair | 5 | 10-03-2008 02:17 PM |
| not draining properly | stickfire | Washer Repair | 5 | 08-26-2008 06:52 PM |
| Dishwasher not working properly | Alexman | Dishwasher Repair | 0 | 06-18-2008 05:18 PM |
