Discuss
Kenmore Ultra Wash II no water
 in
Dishwasher Repair
Everything coming out with white film baked on. Tried "watching" thru cycle and after five minutes still said heating water.
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Kenmore Ultra Wash II no water
  #1 (permalink)
Old 02-06-2010, 11:02 AM
M W M W is offline
Junior Member
M W is on a distinguished road
Default Kenmore Ultra Wash II no water
Model Number: (665) 1675592   Brand: Kenmore   Age: 5 - 10 years
Everything coming out with white film baked on. Tried "watching" thru cycle and after five minutes still said heating water. I ran hot water in sink til hottest. No water at all in dishwasher after five minutes. Could use link to manual as well as any thoughts or suggestions from pros on here. Thanks
Related Models
Hoover 021
Hoover 0510
Hoover 0513
Hoover 0515
Hoover 0517-10
Hoover 0517-20
Hoover 0517-30
Hoover 0519
Hoover 0519-10
Hoover 0519-30
Hoover 0519-60
Hoover 0519-70
Hoover 0519-80
Hoover 0610
Hoover 0611
Hoover 0612
Hoover 0613
Hoover 0617
Hoover 0617-61
Hoover 0617-64
Hoover 0620
Hoover 0622
Hoover 0630
Hoover 0632
Hoover 0710
Hoover 0750
Roper 0773B10 Range Hood
Roper 0783B10 Range Hood
Hoover 0810
Hoover 0811
Hoover 0914
Hoover 0914-61
Hoover 0914-64
Hoover 0916
Hoover 0916T
Hoover 0916T-01
Hoover 0920
Amana 10-2NM ROOM AIR CONDITIONER
Frigidaire 1005 DISHWASHER
Frigidaire 1006 DISHWASHER
Amana 1008.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 1009.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 100A-20 ROOM AIR CONDITIONER
Amana 100A-2M ROOM AIR CONDITIONER
Amana 100A-2N ROOM AIR CONDITIONER
Amana 100A-30 ROOM AIR CONDITIONER
Amana 100A-30H ROOM AIR CONDITIONER
Amana 100A-356 ROOM AIR CONDITIONER
Amana 100A-3A ROOM AIR CONDITIONER
Amana 100A-3HN ROOM AIR CONDITIONER
Amana 100A-3M ROOM AIR CONDITIONER
Amana 100A-3N ROOM AIR CONDITIONER
Amana 100A-3P ROOM AIR CONDITIONER
Amana 100A-3PH ROOM AIR CONDITIONER
Amana 100A-3R ROOM AIR CONDITIONER
Amana 100A-3RH ROOM AIR CONDITIONER
Amana 100A-556 ROOM AIR CONDITIONER
Amana 100A-8R ROOM AIR CONDITIONER
Amana 100B-3A ROOM AIR CONDITIONER
Amana 100C-2N ROOM AIR CONDITIONER
Amana 100C-2N1 ROOM AIR CONDITIONER
Amana 100C-2P ROOM AIR CONDITIONER
Amana 100C-2PH ROOM AIR CONDITIONER
Amana 100C-2R ROOM AIR CONDITIONER
Amana 100C-2RH ROOM AIR CONDITIONER
Amana 100C-2RHL ROOM AIR CONDITIONER
Amana 100C-2RL ROOM AIR CONDITIONER
Amana 100C-3N ROOM AIR CONDITIONER
Amana 100C-3N1 ROOM AIR CONDITIONER
Amana 100C-3P ROOM AIR CONDITIONER
Amana 100C-3PH ROOM AIR CONDITIONER
Amana 100C-3R ROOM AIR CONDITIONER
Amana 100C-3RH ROOM AIR CONDITIONER
Amana 100C-3RHL ROOM AIR CONDITIONER
Amana 100C-3RL ROOM AIR CONDITIONER
Amana 100C-8P ROOM AIR CONDITIONER
Amana 100C-8R ROOM AIR CONDITIONER
Amana 100C-8RH ROOM AIR CONDITIONER
Amana 100C-8RHL ROOM AIR CONDITIONER
Amana 100C-8RL ROOM AIR CONDITIONER
Amana 100D-356 ROOM AIR CONDITIONER
Amana 100D-556 ROOM AIR CONDITIONER
Amana 100LA-20 ROOM AIR CONDITIONER
Amana 100LA-2N ROOM AIR CONDITIONER
Amana 100LC-2N ROOM AIR CONDITIONER
Amana 100LC-2P ROOM AIR CONDITIONER
Amana 100LC-2R ROOM AIR CONDITIONER
Amana 100LC-2RH ROOM AIR CONDITIONER
Amana 100LCS-2N ROOM AIR CONDITIONER
Amana 100LCS-2P ROOM AIR CONDITIONER
Hoover 1010
Amana 1010.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 1011.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 1015.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 1018.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 102.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 102.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 102.002 MWAVE - FAMILY SIZE (60 HZ)
Hoover 1020
Amana 1020.0 MWAVE - FAMILY SIZE (60 HZ)
Amana 1020.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 1021.000 MWAVE - FAMILY SIZE (60 HZ)
Hoover 1022
Amana 1022.000 MWAVE - FAMILY SIZE (60 HZ)
Frigidaire 1026 DISHWASHER
Hoover 1030
Frigidaire 1031-005A DISHWASHER
Hoover 1032
Frigidaire 1032-005A DISHWASHER
Craftsman 10322161 TABLE MITRE SAW
Craftsman 10322180 CRAFTSMAN BENCH SAW
Craftsman 10322181 CRAFTSMAN BENCH SAW
Craftsman 10322420 CRAFTSMAN FLOOR MODEL SAW
Craftsman 10322450 CRAFTSMAN FLOOR MODEL SAW
Craftsman 10322451 CRAFTSMAN FLOOR MODEL SAW
Craftsman 10323150 CRAFTSMAN JIG SAW
Craftsman 10323151 JIG SAW 18 INCH
Craftsman 10323390 CRAFTSMAN JIG SAW
Craftsman 10323420 BENCH SAW
Craftsman 10323440 JIG SAW
  #2 (permalink)
Old 02-06-2010, 11:05 AM
M W M W is offline
Junior Member
Default
oooh quick update...I started it again and now right away water in tub....
  #3 (permalink)
Old 02-08-2010, 01:22 PM
M W M W is offline
Junior Member
Default
Update: ran thru the cycle three times this weekend to try to see what I have going on. Two times the DW started fine but sat "heating the water" for 5 minutes then 10+ minutes. Each cycle seemed very long overall. Not sure how long it should last from start to finish. While it was in "delay, heating water" mode I kept opening it anc checking water temp. Never did get very hot. The one time it worked fine (but entire cycle seemed long) the water was very hot and when I opened it to check it steamed out.
Ok...any ideas? Thanks
  #4 (permalink)
Old 02-10-2010, 11:32 AM
M W M W is offline
Junior Member
Default
Bump hoping for reply
  #5 (permalink)
Old 02-11-2010, 04:08 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Could not find any tech info using the model number so the following is a bit of a guess
https://secured.whirlpool.com/Servic...E/4322451L.pdf
Check the thermostats with a meter they should be attached to the tub under the unit.
Check the heating element with a meter.
If it has a heater off/on button check that switch.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Ultra Wash not draining Stina Dishwasher Repair 2 10-16-2010 11:58 AM
kenmore ultra wash quiteguard4 cuyonon Dishwasher Repair 0 09-17-2009 04:35 PM
Kenmore Ultra Wash III cableaving Dishwasher Repair 0 10-05-2008 10:00 AM
Kenmore Ultra Wash Drain? gsequel1 Dishwasher Repair 2 09-09-2008 07:47 AM
Kenmore Ultra Wash Will Not Heat Water mikedmann Dishwasher Repair 6 03-08-2008 10:56 AM
