Discuss
Bosch Dishwasher Will Not fill with water
 in
Dishwasher Repair
I began my dishwasher a couple of mornings ago and found that my kitchen sinks were clogged. I had already
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Bosch Dishwasher Will Not fill with water
  #1 (permalink)
Old 04-26-2008, 11:24 PM
drskinner drskinner is offline
Junior Member
drskinner is on a distinguished road
Default Bosch Dishwasher Will Not fill with water
Model Number: SHU 3036   Brand: Bosch   Age: 5 - 10 years
I began my dishwasher a couple of mornings ago and found that my kitchen sinks were clogged. I had already started the washing cycle and as it drained, it backed up into the sinks. I shut the dishwasher off, ran the garbage disposal to try and clear the clog to no avail. Eventually my husband was able to use a plumber's snake to clear the clog, but before the clog was cleared, the water backed up into the dishwasher. Neither I nor my husband noticed this until that evening when we returned home to find our wood floor buckled in front of the dishwasher. We proceeded to start the dishwasher to complete the wash cycle from earlier in the day. At that time, we noticed that no water was feeding into the dishwasher, but the knob seemed to be running through the cycle. When we took the front kickplate off, we expected to see water under the dishwasher, but did not. Instead, we found that the door seemed to be leaking water at the bottom, like the insulation was wet. We tried our best to absorb all of the water there, and are placing a fan on it tonight to see if we can get it dried out. Could this have caused some problem that would not allow water to feed into the various cycles? We have checked all of the water feed lines and they are fine.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dishwasher won't fill cas Dishwasher Repair 1 04-16-2008 04:53 PM
Dishwasher will not fill with water linda alabama Dishwasher Repair 2 02-11-2008 06:59 PM
dishwasher won't fill with water jhmorlang Dishwasher Repair 3 02-08-2008 02:46 PM
Bosch dishwasher not filling with water rritter Dishwasher Repair 3 01-17-2008 09:10 PM
GE washer will not fill with water tex Dishwasher Repair 1 08-30-2007 12:33 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
