90partridge
#1 Posted : Thursday, February 4, 2010 7:00:25 AM(UTC)
90partridge
dishwasher started and was running, then stopped in the middle of the cycle and shut off. Unable to get it started again.
#2 Posted : Friday, February 5, 2010 5:04:23 AM(UTC)
Replacement parts for WHIRLPOOL KUDS25SHWH1 | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208051291.pdf
As always when a unit is dead check that the breaker has not tripped.
Next check that the unit is getting power where it is hooked to the house wiring.
Several months ago had a run of people where the connections in the wire nuts were bad.
Next would be the thermal fuse (Item 22 in Section 3)
Check it with a meter.
If blown be sure to use the new harness.
Note: this fuse can blow due to temperature or current, so check the other components for resistance especially the wax motors if your unit uses them.
If OK next would be the door switches.
Hotpoint dishwasher not working (Dishwasher Repair)
by Guest 7/25/2022 1:43:03 PM(UTC)
Whirlpool Dishwasher Not Working (Dishwasher Repair)
by krupp72001 11/8/2015 2:46:14 PM(UTC)
Maytag Dishwasher not working (Dishwasher Repair)
by jtmcgarry 11/11/2013 1:39:59 PM(UTC)
Ge dishwasher not working (Dishwasher Repair)
by Philip Robertson 8/20/2013 10:10:42 AM(UTC)
Quiet Partner II Dishwasher Not Working (Dishwasher Repair)
by lhemenwayga 7/25/2013 1:00:36 PM(UTC)
Whirlpool Dishwasher not working, Help? (Dishwasher Repair)
by rosesprosper 1/18/2013 7:58:53 AM(UTC)
by ellene 1/16/2013 8:37:44 AM(UTC)
by PhoenixAlbertini 7/11/2012 6:04:48 PM(UTC)
Frigidaire Dishwasher not working (Dishwasher Repair)
by Brandilove21 4/11/2012 2:06:47 PM(UTC)
Boesch Dishwasher Not working (Dishwasher Repair)
by juliem922 3/23/2012 9:43:20 AM(UTC)
Maytag dishwasher not working right Help! (Dishwasher Repair)
by ski00 10/31/2011 7:30:32 AM(UTC)
How Do I Troubleshoot Dishwasher Not Working (Dishwasher Repair)
by Dianne Bennett 10/18/2011 2:55:07 PM(UTC)
Kitchen Aid Superba Dishwasher Not Working (Dishwasher Repair)
by oakdaledishwasher 8/15/2011 8:03:02 PM(UTC)
Control buttons on GE dishwasher not working (Dishwasher Repair)
by summer1234 8/13/2011 6:40:13 AM(UTC)
Kenmore Dishwasher not working (Dishwasher Repair)
by Mr. Gooey 7/28/2011 3:50:55 PM(UTC)
