"Just for update purposes...the replacement part I ordered/received for the Central Control Unit of my Kenmore HE4T washer back in October, 2009...I have finally installed on the washer (the washer worked ok for a while after taking the top off so I did nothing until the F11 and Fdl error codes began happening again)AND.SO..the part is but it isn't the proper replacement part....the washer works but only on 2 cycles...Soak and Kids Wear (2 hr cycle). I understand it is a current replacement part # for the original part...but there must be some wiring differences to cause the operating keypad to effectively be useless except on the 2 cycles mentioned. In my searching the web, I have noticed that some others have had the same exact problem. Does anyone have any solution to this or will I either have to junk this expensive washer or live with these 2 cycles only???"
