| » Dishwasher - Top washing arm does not spin |
Model Number: PLDB998AC1 Brand: Frigidaire Age: 5 - 10 years
Our dishwasher is not working properly. The top arm is not spinning, thus the dishes are not being cleaned properly. Just a simple troubleshoot, I started the top rack wash only and set the arm in position, waited about ten minutes into the wash cycle, and the arm was in the same position. It did have water dripping down, but apparently not enough to make the arm spin. I believe the amount of water pressure is somehow reduced, thus not causing the arm to spin. Any suggestions???
Here are the parts
Replacement parts for FRIGIDAIRE PLDB998AC1 Frigidaire/dishwasher | AppliancePartsPros.com Here is the tech sheet http://manuals.frigidaire.com/prodin.../154415101.pdf Here is a manual that should be close to yours http://frigidaireservicetips.com/pdfs/484_2.pdf I am assuming you manually spun the upper arm and it is OK. Often low pressures are due to dirty filters or junk in the impeller area. Clean and check. Sometimes it is because the unit is not filling to the correct level. Though usually you can hear this as the pump starts to suck in air. Most units will fill to just under or just over the heating element. Just under is the most common. But I do not know which is correct on this unit. This can be checked by adding a couple quarts of hot water just after it fills. Just be careful not to overfill it. If it then washes OK, it is probably a dirty screen filter on the input side of the water valve.
__________________
| Display Modes | |
| washing machine will not spin | robins | Washer Repair | 1 | 11-05-2009 05:07 PM |
| Washing Machine doesn't spin | CSand | Washer Repair | 1 | 05-29-2009 07:10 PM |
| Washing Machine will not spin in the spin cycle | totoro00us | Washer Repair | 9 | 12-27-2008 04:22 AM |
| Dishwasher is stuck on washing status--buzzing NOT washing | cerebralgent | Dishwasher Repair | 3 | 10-30-2008 09:59 AM |
| washing machine won't spin | dejoel | Washer Repair | 5 | 10-24-2008 02:18 PM |
