| » Whirlpool Dishwasher Stuck in Cycle |
Model Number: DU900PCDQO Brand: Whirlpool Age: More than 10 years
Help please.. My dishwasher is not cycling through and gets stuck in wash mode. This is what I have found..
-Timer seems ok, as it only gets stuck in wash cycle but runs through in dry area -Water temp into machine is 130 degrees and heater seems fine I have checked the continuity of both the thermostat and high limit with unit as room temp unplugged. -Thermostat read 0, which is the same when I touch the leads of the meter together.. -High Limit does not read zero so i would assume that is called open... HELP? I think I am close to figuring out the problem... |
Actually one thermostat should show open at room temp.
Its the one thats connected to the timer motor circuit. The wire colors connected to it are white with a black tracer and tan with a red tracer. The high limit should show closed. Its the one that connected to the heating element. One wire is orange and the other is white with a red tracer. Look closely at all areas of the thermostat you said checked open. Are there any numbers printed or stamped into the metal areas of the part? If so what are they ? One of them might start with an "L" thank you |
Hi there and thanks for the reply. So I am stuck. I have replaced the timer, thermostat, and the high limit and still no luck. Doesn't not want to leave the wash cycle..
Not sure what else the issue might be. Washer is 12-13 years old. Is it time to be replaced? Help.. |
Double check and make sure that the thermostats are in the
right place (or order). The one that is "normally closed" at room temp should be hook in line with the heating element (the wire colors are in my last post). And make sure the one that connects in series with the timer is the one that is "normally open" at room temp. Last edited by glen65 : 04-23-2008 at 06:49 PM. |
| Display Modes | |
| Dishwasher gets stuck in cycle | woodieb1 | Dishwasher Repair | 4 | 05-10-2008 08:44 PM |
| Whirlpool dishwasher won't cycle | deak71 | Dishwasher Repair | 1 | 04-14-2008 09:06 PM |
| Bosch dishwasher stuck on rinse cycle | JDDrake | Dishwasher Repair | 2 | 04-05-2008 11:10 AM |
| Whirlpool stuck in rinse cycle | vegemom | Dishwasher Repair | 5 | 01-30-2008 11:09 AM |
| Maytag dishwasher stuck on drain cycle | ak47jazzfan | Dishwasher Repair | 3 | 10-15-2007 11:35 PM |
