Admits water, fools around for a while and pumps water out. Soap drips down inside of door but there's no evidence of it being 'used.'
The washer came with a new controller card (642147) that may not have been installed properly. A local repair place said the controller/card may not have been 'programmed.' That was described as putting the machine through a cycle by pushing the appropriate buttons in sequence. Does anyone here know if that's true?
I thought perhaps I could do that if I could get a description of the proper sequence of button pushes. They want about $100 to visit and do that.
