| » Screw holding wash impellar won't loosen |
Model Number: 665.16831790 Brand: Kenmore Age: 1 - 5 years
I have new parts to repair this dishwasher. Trying to loosen the screw holding the wash impellar(the impellar has 6 flats on it to keep it from turning) the motor shaft the screw is screwed into keeps turning but the wash impellar won't turn because of a wrench on the flats. Is there anyway to prevent (lock the motor shaft?) the motor shaft from turning, so the screw will loosen?
Thanks for your help |
there is special wrench for impeller .then use 1/4 inch socket or nut driver. socket is better. some times you have to break impellor to get off ,+get new ne impeller seal kit
__________________
You can try a pair of vice grips on the old impeller to get the screw off. Once screw is off, I use a sharp wood chisel to bust the old one off. If you sheer off the screw, you can epoxy the new impeller on
__________________
| Display Modes | |
| Got a 'screw loose'! | Paul James | Dishwasher Repair | 1 | 02-06-2008 08:13 PM |
| Electric Dryer Will Not Run W/o Holding In Start Button | niggdj@bluemarble.net | Dryer Repair | 10 | 01-02-2008 08:45 PM |
| dishwasher won't wash | George Beacher | Dishwasher Repair | 1 | 12-29-2007 03:43 PM |
| dishrack screw type | jfazekas60 | Dishwasher Repair | 1 | 09-10-2007 07:46 PM |
| Can not select wash cycle - stuck on scrub wash | luke | Dishwasher Repair | 0 | 08-20-2007 09:38 AM |
