Discuss
Whirlpool Quiet Partner II
 in
Dishwasher Repair
Dishwasher only works in Light Wash mode.....other modes will not work and their led's do not light. Ads By Google
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Whirlpool Quiet Partner II
  #1 (permalink)
Old 01-27-2010, 07:26 AM
Junior Member
cocodon is on a distinguished road
Default Whirlpool Quiet Partner II
Brand: Whirlpool   Age: 1 - 5 years
Ads By Google
  #2 (permalink)
Old 01-28-2010, 04:30 AM
Senior Expert
APP Volunteer
denman is a glorious beacon of light
Default
A model number may help others help you.
Try the following
Connector Cleaning / Checking
Unplug the unit
Open it up
Remove the ribbon cable from the keypad to the control board at the control board.
Clean the edge connector.
If it is the type where there is not a connector just the insulation is removed, it can be cleaned with a pencil eraser. Do not use an ink eraser as it is too abrasive.
Check the tracks in the ribbon cable for hairline cracks. A magnifying glass helps here.
Would not hurt to clean the connector on the board. Use electronics contact cleaner or isopropyl alcohol and a tooth brush. Be gentle and do not reconnect till all the solvent evaporates.
Reconnect everything and give it a try.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
whirlpool quiet partner 3 Shannon Coe Dishwasher Repair 6 09-12-2011 11:52 AM
Whirlpool Quiet Partner II Gallexy Dishwasher Repair 3 11-18-2009 07:58 AM
Whirlpool Quiet Partner I Fran Button Dishwasher Repair 0 06-12-2009 01:04 PM
Whirlpool Quiet Partner III tdonovan Dishwasher Repair 6 03-16-2009 05:02 PM
Whirlpool Quiet Partner III Lenwann Dishwasher Repair 2 03-08-2009 12:12 PM
