oldman39
#1 Posted : Tuesday, January 26, 2010 7:29:51 PM(UTC)
oldman39
Dishwasher detergent dispenser wont open during wash. Sometimes it is wet & hard today it was dry . No tall utensils were in front to dispenser.
#2 Posted : Wednesday, January 27, 2010 2:19:00 AM(UTC)
I cannot find info on a TS02 but there is a TSQ2.
Please check your model number.
Could be the solenoid or wax motor which opens the door is burned out.
