That guy from Florida
#1 Posted : Tuesday, January 26, 2010 8:34:28 AM(UTC)
Model is DWU 4915 BAX
Will fill with water, but won't cycle any farther than that.
Have to drain it by resetting the cycle to the beginning.
also makes a humming noise when it is trying to cycle, but nothing happens.
I am down to either the motor or the landfill with this thing.
Any suggestions?
#2 Posted : Wednesday, January 27, 2010 2:36:53 AM(UTC)
Pump & motor replacement parts for MAYTAG DWU4915BAX Dishwasher - Undercounter | AppliancePartsPros.com
Here is a service manual, although it does not specifically cover your unit is is the best I can find. The 4910 may be close to yours.
http://www.servicematters.com/maytag_library/html/index.html
I would check that the pump can mechanically turn in both directions.
Since drain works OK could be the wash winding is open, I would check it with a meter for continuity.
May also be a dirty timer contact for the wash winding.
#3 Posted : Wednesday, February 29, 2012 2:16:20 PM(UTC)
I never got back to you guys. It worked perfectly after replacing the pump. Thank you for your help!
D
