Discuss
dparden68
 in
Dishwasher Repair
I replaced the thermal fuse and it ran for 4 to 6 hours and thermal fuse blew agian. What else
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » dparden68
  #1 (permalink)
Old 01-25-2010, 05:18 AM
Junior Member
dparden68 is on a distinguished road
Default dparden68
Model Number: HYE3658AYW   Brand: Maytag   Age: 5 - 10 years
I replaced the thermal fuse and it ran for 4 to 6 hours and thermal fuse blew agian. What else could be wrong. I think it might be the t-stat hilimit, because the heating elment looks fine and checks out fine. Could anybody confirm this for me.
Ads By Google
Related Models
Maytag HYE3658AYW Dryer - Ele
Maytag HYE3658AZS Dryer - Ele
Maytag HYE3658AZW Dryer - Ele
Maytag HYG2460AWW Dryer - Gas
Maytag HYG3460AWW Dryer - Gas
Maytag HYG3657AWW Dryer - Gas
Maytag HYG3658AWW Dryer - Gas
Amana HZ1070 Dryer - Ele
Amana I2000 Mwave - Family Size (60 Hz)
Whirlpool IACS50
Whirlpool IACS501
Whirlpool IACS50E
Whirlpool IACS50E1
Whirlpool IAS5000RQ0 Automatic Washer
Whirlpool IAS5000RQ1 Automatic Washer
Whirlpool IAS5000RQ2 Automatic Washer
Whirlpool IAX4000RQ0 Automatic Washer
Whirlpool IAX4000RQ1 Automatic Washer
Whirlpool IAX4000RQ2 Automatic Washer
Whirlpool IBD550PRS00 30" Built - in Electric Double Oven Self Clean Thermal Convection
Whirlpool IBD550PRS02 30" Built - in Electric Double Oven Self Clean Thermal Convection
Whirlpool IBS124PSS00 24" Built - in Electric Oven Convection
Whirlpool IBS224PSM00 24" Built - in Electric Oven Convection
Whirlpool IBS324PSW00 24" Built - in Electric Oven Convection
Whirlpool IBS330PRS01 30" Built - in Electric Oven Self Clean
Whirlpool IBS330PRS02 30" Built - in Electric Oven Self Clean
Whirlpool IBS550PRQ00 30" Built - in Electric Oven Self Clean Thermal Convection
Whirlpool IBS550PRQ01 30" Built - in Electric Oven Self Clean Thermal Convection
Whirlpool IBS550PRQ02 30" Built - in Electric Oven Self Clean Thermal Convection
Whirlpool IBS550PRS00 30" Built - in Electric Oven Self Clean Thermal Convection
Whirlpool IBS550PRS01 30" Built - in Electric Oven Self Clean Thermal Convection
Whirlpool IBS550PRS02 30" Built - in Electric Oven Self Clean Thermal Convection
Whirlpool IBS550PRS03 30" Built - in Electric Oven Self Clean Thermal Convection
Amana IC-2 Ref - Top Mount
Amana IC-3H Ref - Top Mount
Amana IC2 Misc / Accessory
Amana IC3 Misc / Accessory
Amana IC3H Misc / Accessory
Amana IC3K Misc / Accessory
Amana IC3N Misc / Accessory
Amana IC3Q Misc / Accessory
Amana IC4 Misc / Accessory
Amana IC4N Misc / Accessory
Amana IC4Q Misc / Accessory
Amana IC4R Misc / Accessory
Amana IC52 Misc / Accessory
Whirlpool IC5E
Amana IC6 Misc / Accessory
Maytag ICE Misc / Accessory
International ICE-25 Misc / Accessory
International ICE-26 Misc / Accessory
Admiral ICES24F9 Ref - SXS/I&W
Admiral ICES24F9A Ref - SXS/I&W
Admiral ICES24F9H Ref - SXS/I&W
Admiral ICNF17E8 Freezer - Vertical
Admiral ICNS22F9 Ref - SXS/I&W
Admiral ICNS22F9A Ref - SXS/I&W
Admiral ICNS22F9H Ref - SXS/I&W
Admiral ICNS24F9 Ref - SXS/I&W
Admiral ICNS24F9A Ref - SXS/I&W
Admiral ICNS24F9H Ref - SXS/I&W
Admiral ICNS28D9 Ref - SXS/I&W
Admiral ICNS28D9- Ref - SXS/I&W
Admiral ICNS28D92 Ref - SXS/I&W
Admiral ICNS28D92A Ref - SXS/I&W
Admiral ICNS28D92H Ref - SXS/I&W
Admiral ICNS28D9A Ref - SXS/I&W
Admiral ICNS28D9F Ref - SXS/I&W
Admiral ICNS28D9H Ref - SXS/I&W
Admiral ICNT18F9L Ref - Top Mount/ I&W
Admiral ICNT18F9LA Ref - Top Mount/ I&W
Admiral ICNT18F9LH Ref - Top Mount/ I&W
Admiral ICNT22F93 Ref - Top Mount/ I&W
Admiral ICNT22F93A Ref - Top Mount/ I&W
Admiral ICNT22F93H Ref - Top Mount/ I&W
Admiral ICNT22F9L Ref - Top Mount/ I&W
Admiral ICNT22F9LA Ref - Top Mount/ I&W
Admiral ICNT22F9LH Ref - Top Mount/ I&W
Whirlpool ICR410RB00 30" Electric Ceran Built - in Cooktop
Whirlpool ICR410RB01 30" Electric Ceran Built - in Cooktop
Whirlpool ICR410RP01 30" Electric Ceran Built - in Cooktop
Whirlpool ICR416RB00 36" Electric Ceran Built - in Cooktop
Whirlpool ICR416RB01 36" Electric Ceran Built - in Cooktop
Whirlpool ICR416RP00 36" Electric Ceran Built - in Cooktop
Whirlpool ICR416RP01 36" Electric Ceran Built - in Cooktop
Whirlpool ICS300RQ00 30" Gas Cooktop
Whirlpool ICS300RQ01 30" Gas Cooktop
Whirlpool ICS300RQ02 30" Gas Cooktop
Whirlpool ICS300RS00 30" Gas Cooktop
Whirlpool ICS300RS01 30" Gas Cooktop
Whirlpool ICS300RS02 30" Gas Cooktop
Whirlpool ICS304SM00 30" Gas Cooktop
Whirlpool ICS306RS00 36" Gas Cooktop
Whirlpool ICS306RS01 36" Gas Cooktop
Whirlpool ICS404SB00 30" Gas Cooktop
Whirlpool ID2GFGXRS00 Refrigerator
Whirlpool ID2GFGXRS01 Refrigerator
Whirlpool ID2HHEXTS00 Refrigerator
Whirlpool ID2HHEXTS01 Refrigerator
Whirlpool ID5GFGXRQ00 Refrigerator
Whirlpool ID5GFGXRQ01 Refrigerator
Whirlpool ID5GFGXRQ02 Refrigerator
  #2 (permalink)
Old 01-27-2010, 04:08 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Here are your parts includes a wiring diagram
Replacement parts for MAYTAG HYE3658AYW Dryer - Ele | AppliancePartsPros.com
See below
Check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on high and the thermostats cannot regulate it. Check for tell tale arc marks on the inside of the heater case could be it sags when hot then returns to normal when it cools down.
If the heater is OK then I would also replace the hi-limit thermostat as this should have regulated the temperature so that the fuse did not blow.
You still have to find the cause.
It could be:
A dirty/loose blower wheel
A dirty vent system or it's outside louvers are not opening.
A bad cycling (control) thermostat. Note this is a 4 connector thermostat.
One set is the contacts. The other set is the internal heater, should be around 25,000 ohms. This is used to give you different heat settings.
Also check the internal seals re: drum etc. The thermostat is on the blower so if it can suck in cool air past a seal then it will run the dryer too hot, though the hi-limit should have prevented the fuse from blowing.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
dparden68 dparden68 Dryer Repair 1 01-27-2010 05:34 AM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
