Discuss
Kenmore dishwasher doesn't spray/clean well
 in
Dishwasher Repair
OK, I've been on the boards and read as much as I can find. The problem appears to be that
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Kenmore dishwasher doesn't spray/clean well
  #1 (permalink)
Old 01-24-2010, 04:43 PM
Junior Member
cbprincipal is on a distinguished road
Default Kenmore dishwasher doesn't spray/clean well
Model Number: 665.17372301   Brand: Kenmore   Age: 5 - 10 years
OK, I've been on the boards and read as much as I can find. The problem appears to be that the dishwasher doesn't fill completely. I should be getting about 1.5 gallons in the fill cycle but seem to get less than that.
When I add extra water, it seems to run fine, and both upper and lower arms turn.
Here is what I have done so far:
-took off and checked both arms for obstructions -- nothing
-checked the accumulator cover and sump for debris -- nothing
-took off the inlet protector and checked the chopper and screen for debris/obstruction -- nothing
- replaced the sump check valve -- no improvement
- removed the pump assembly and checked the impeller for damage or obstruction -- nothing. Everything turns freely and looks fine.
- checked resistance of the solenoid -- 986 ohms, which is in the range expected.
- took off the fill valve and checked for obstruction -- a couple of small bits of debris. Nothing that looked big enough to impair flow.
- checked water supply line for flow -- plenty.
So.... is there any other reason that there isn't enough water coming in? Should I just replace the fill valve? Comments/suggestions welcome!!
Ads By Google
Related Models
Kenmore 665.4098450  BUILT-IN OVEN
Kenmore 665.4098451  RANGE - ELEC
Kenmore 665.4098452  BUILT-IN OVEN
Kenmore 665.4098890  ELECTRIC BUILT-IN OVEN
Kenmore 665.4098910  ELEC. BUILT-IN OVEN
Kenmore 665.4098911  BUILT IN-ELEC. OVEN
Kenmore 665.4098912  BUILT-IN OVEN
Kenmore 665.4098913  BUILT-IN OVEN
Kenmore 665.4098914  ELEC. BUILT-IN OVEN
Kenmore 665.4098915  ELECTRIC BUILT-IN OVEN
Kenmore 665.4098990  BUILT IN WALL OVEN
Kenmore 665.4098991  BUILT-IN ELEC. OVEN
Kenmore 665.4098992  BUILT-IN OVEN
Kenmore 665.4098993  BUILT-IN OVEN
Kenmore 665.4098994  ELEC. BUILT-IN OVEN
Kenmore 665.4098995  ELECTRIC BUILT-IN OVEN
Kenmore 665.4098996  RANGE - ELEC
Kenmore 665.4098997  BUILT IN OVEN
Kenmore 665.42500  KENMORE COMPACTOR
Kenmore 665.42501  KENMORE COMPACTOR
Kenmore 665.42550  KENMORE COMPACTOR
Kenmore 665.42551  KENMORE COMPACTOR
Kenmore 665.42600  KENMORE COMPACTOR
Kenmore 665.42601  KENMORE COMPACTOR
Kenmore 665.427303-1  COMPACTOR
Kenmore 665.427303-2  COMPACTOR
Kenmore 665.427303-3  COMPACTOR
Kenmore 665.427303-4  COMPACTOR
Kenmore 665.427303-5  COMPACTOR
Kenmore 665.4428451  RANGE - ELEC
Kenmore 665.4428996  ELECTRIC DOUBLE OVEN BUILT-IN
Kenmore 665.4428997  RANGE - ELEC KENMORE
Kenmore 665.4428998  BUILT IN OVEN
Kenmore 665.4433450  BUILT-IN OVEN AND MICROWAVE
Kenmore 665.4433451  BUILT IN OVEN WITH MICROWAVE OVEN
Kenmore 665.4433452  ELEC BUILT-IN OVEN / MICROWAVE
Kenmore 665.4438890  MICRO/ELECTRIC BUILT-IN OVEN
Kenmore 665.4438913  BUILT-IN OVEN/MICRO
Kenmore 665.4438990  MICROWAVE OVEN
Kenmore 665.4438995  BUILT-IN OVEN/MICRO
Kenmore 665.4493392  MICROWAVE
Kenmore 665.4493393  ELEC BUILT-IN OVEN AND MICROWAVE
Kenmore 665.4558953  ELECTRIC COOKTOP / BUILT-IN OVEN
Kenmore 665.4558995  ELECTRIC COOKTOP
Kenmore 665.45755690  30" ELECTRIC DROP-IN RANGE
Kenmore 665.45755691  30" ELECTRIC DROP-IN RANGE
Kenmore 665.45759690  30" ELECTRIC DROP-IN RANGE
Kenmore 665.45759691  30" ELECTRIC DROP-IN RANGE
Kenmore 665.4579351  ELECTRIC RANGE
Kenmore 665.4579391  BUILT-IN RANGE
Kenmore 665.60601000  MICROWAVE/HOOD COMBO
Kenmore 665.60609000  MICROWAVE/HOOD COMBO
Kenmore 665.60612000  MICROWAVE/HOOD COMBO
Kenmore 665.60617000  MICROWAVE/HOOD COMBO
Kenmore 665.60619000  MICROWAVE/HOOD COMBO
Kenmore 665.60622000  MICROWAVE/HOOD COMBO
Kenmore 665.60629000  MICROWAVE/HOOD COMBO
Kenmore 665.60632000  MICROWAVE/HOOD COMBO
Kenmore 665.60639000  MICROWAVE/HOOD COMBO
Kenmore 665.60652000  MICROWAVE/HOOD COMBO
Kenmore 665.60654000  MICROWAVE/HOOD COMBO
Kenmore 665.60657000  MICROWAVE/HOOD COMBO
Kenmore 665.60659000  MICROWAVE/HOOD COMBO
Kenmore 665.60682000  MICROWAVE/HOOD COMBO
Kenmore 665.60689000  MICROWAVE/HOOD COMBO
Kenmore 665.61601100  MICROWAVE
Kenmore 665.61609100  MICROWAVE
Kenmore 665.61612100  MICROWAVE/HOOD COMBO
Kenmore 665.61614100  MICROWAVE/HOOD COMBO
Kenmore 665.61617100  MICROWAVE/HOOD COMBO
Kenmore 665.61619100  MICROWAVE/HOOD COMBO
Kenmore 665.61622100  MICROWAVE/HOOD COMBO
Kenmore 665.61624100  MICROWAVE/HOOD COMBO
Kenmore 665.61627100  MICROWAVE/HOOD COMBO
Kenmore 665.61629100  MICROWAVE/HOOD COMBO
Kenmore 665.61632100  MICROWAVE/HOOD COMBO
Kenmore 665.61639100  MICROWAVE/HOOD COMBO
Kenmore 665.61652100  MICROWAVE/HOOD COMBO
Kenmore 665.61652101  MICROWAVE/HOOD COMBO
Kenmore 665.61652102  MICROWAVE/HOOD COMBO
Kenmore 665.61654100  MICROWAVE/HOOD COMBO
Kenmore 665.61654101  MICROWAVE/HOOD COMBO
Kenmore 665.7042700  SEARS COMPACTOR
Kenmore 665.7042701  KENMORE COMPACTOR
Kenmore 665.7242600  SEARS KENMORE COMPACTOR
Kenmore 665.7242601  SEARS COMPACTOR
Kenmore 665.7242602  KENMORE COMPACTOR
Kenmore 665.7242700  KENMORE COMPACTOR
Kenmore 665.7242701  SEARS COMPACTOR
Kenmore 665.7242702  KENMORE COMPACTOR
Kenmore 665.7242703  KENMORE COMPACTOR
Kenmore 665.7242705  KENMORE COMPACTOR
Kenmore 665.7242706  KENMORE COMPACTOR
Kenmore 665.7242707  KENMORE COMPACTOR
Kenmore 665.7242751  SEARS COMPACTOR
Kenmore 665.7342200  KENMORE COMPACTOR
Kenmore 665.7342201  KENMORE COMPACTOR
Kenmore 665.7342202  KENMORE COMPACTOR
Kenmore 665.7342203  KENMORE COMPACTOR
Kenmore 665.7342204  KENMORE COMPACTOR
Kenmore 665.7342300  KENMORE COMPACTOR
Kenmore 665.7342400  KENMORE COMPACTOR
Kenmore 665.7342401  KENMORE COMPACTOR
Kenmore 665.7342402  KENMORE COMPACTOR
Kenmore 665.7342403  KENMORE COMPACTOR
Kenmore 665.7342404  KENMORE COMPACTOR
Kenmore 665.7342600  KENMORE COMPACTOR
Kenmore 665.7342610  KENMORE COMPACTOR
Kenmore 665.7342611  KENMORE COMPACTOR
Kenmore 665.7342612  KENMORE COMPACTOR
Kenmore 665.7342613  KENMORE COMPACTOR
Kenmore 665.7342700  KENMORE COMPACTOR
Kenmore 665.7342701  KENMORE COMPACTOR
Kenmore 665.7342702  KENMORE COMPACTOR
Kenmore 665.7342703  KENMORE COMPACTOR
Kenmore 665.7342704  KENMORE COMPACTOR
Kenmore 665.7342900  KENMORE COMPACTOR
Kenmore 665.7342901  KENMORE COMPACTOR
Kenmore 665.7342902  KENMORE COMPACTOR
Kenmore 665.7342903  KENMORE COMPACTOR
  #2 (permalink)
Old 01-27-2010, 04:16 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Here is a tech sheet for your unit which is actually a Whirlpool
http://www.servicematters.com/docs/w...%208537797.pdf
Could be something weird like a timer issue but it is unlikely.
That is what I would do as you have done a thorough job of troubleshooting and it is at the top of the list as the cause.
__________________
  #3 (permalink)
Old 01-27-2010, 06:55 PM
Junior Member
Default
Thanks -- I'll give it a try.
  #4 (permalink)
Old 02-20-2010, 05:36 PM
Junior Member
Default
Quote:
Denman,
The new fill valve worked like a charm -- thanks!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Dishwasher won't spray jap1561 Dishwasher Repair 1 06-24-2011 12:27 PM
Kenmore Dishwasher Middle spray arm problem TJ Bibbs Dishwasher Repair 0 11-05-2009 02:42 PM
Kenmore dishwasher inconsistent clean cnjemerson Dishwasher Repair 0 08-18-2009 10:56 AM
Kenmore dishwasher blinks clean lite pecosb1 Dishwasher Repair 0 02-25-2009 04:49 PM
Kenmore Dishwasher Upper Rack Does not Clean san Dishwasher Repair 6 04-30-2008 05:58 PM
