Wes
my dishwasher started by working occasionally. I could play with it and get it to work a cycle here and there then it quit. When I pressed a cycle button, instead of numbers appearing on the lcd only a vertical dash appeared. The position of the dash depended on which cycle. I ordered and installed the microcomputer and it is still the same after installing. I found out that if I press normal wash and china wash at the same time the lcd shows 78(which is the number that usually comes up when you press normal wash(when it works properly))Now what? A control panel?this almost seems absurd to spend that much money after sinking a hundred already. Thanks
Wes
