| » bosch dishwasher troubleshoot manual |
LinkBack (10) | Thread Tools | Search this Thread | Display Modes |
thanks for the 2001 repair manual. Does anyone have a manual for those Bosch DW after 2001 like the shu9955?. (Yes I have the "run-on" 2hr plus problem as all the others.( Perhaps Bosch wants to pay this water bill.)
The most recent status is the control module is not available. |
Quote:
- The control module Part number: AP2804417 Gene.
__________________
Professional appliance repair in Orange County, California. |
This is interesting- the one I need for SHX46UC02 model is on backorder too. These things are going faster than Bosch can have them made. And they tell me that this is rare and unusual.....
I will repair my control module with a new relay; the one thats in there seems to be the culprit. I got my idea here: Bosch Dishwasher Control Module (266746)**|**ApplianceJournal.com read MrMark52 post from August 28, 2009 Anyone have any more info on that? |
I have a SHU66C that fills, drains, but takes a very long time and doesn't clean. I suspect the circulation pump. Does anyone know if the diagnostics posted by Harold will help me and which one?
Thanks, BCW |
Not sure about your specific diagnostics. I would rule out circuitboard problem first before starting to replace other parts. All you have to do is visual inspection. Any dark burnt spots on it?
Thanks SBK. I will do as you suggested, but it appears the control module is in short supply. However, I am an electrical engineer and will try to fix the CB if I see a problem. Now, how do I get at the circuit board?
BCW --------------------------- I got to the board and looked for problems but only found what might have been a cold solder joint. I fixed the solder joint and re-assembled the DW only to have the same problem. With the exception of Rinse & hold= 10, all the other cycles times still look strange, maybe backwards: regular wash=146, scrub wash= 116, power scrub plus=102. Ran the diagnostic for the SHU68 (hoping it would be similar to my SHU66) and the readout said "20". Pushing the two buttons to advance the test to the next step resulted in a "0"= no faults found. Any thoughts? Last edited by BCW : 11-10-2009 at 05:30 PM. Reason: Charged ahead to dismantle the door, etc. |
You can use the instructions attached to this reply.
If you need the correct part numbers, post the end of the model number. Here are the breakdown diagrams and Replacement parts for BOSCH SHU66C06 UC/14 (FD 8211-) | AppliancePartsPros.com Gene.
__________________
Quote:
Bosch Dishwasher Control Module (266746)**|**ApplianceJournal.com you will also find interesting fix for replacing relay on circuit board. |
Thanks Gene and sbk - - - you guys are GREAT!
I wish I had waited for Gene's reply, especially the part about "BUT NOT THE BIG HINGE SCREWS AT THE BOTTOM". Yikes, what a mess I made - - - but got it back together finally. Reminds me of the quote, "God grant me patience and I want it right now!" Still have the same problem(s), but now I am afraid to order a circulating pump ($185) without a clue to the cycle and display problems. Maybe a new DW? BCW |
LinkBack to this Thread: http://forum.appliancepartspros.com/dishwasher-repair/7123-bosch-dishwasher-troubleshoot-manual.html
| Posted By | For | Type | Date |
| Bosch 2042 (and others?) fill valve tip - ApplianceBlog.com - Appliance Repair Forums | This thread | Refback | 09-17-2009 09:27 AM |
| www.elektronik.si :: Poglej temo - Bosch pomivalni stroj | This thread | Refback | 09-02-2009 07:27 AM |
| www.elektronik.si :: Poglej temo - Bosch pomivalni stroj | This thread | Refback | 07-18-2009 11:54 AM |
| www.elektronik.si :: Poglej temo - Bosch pomivalni stroj | This thread | Refback | 06-30-2009 12:17 AM |
| Help - does anyone own a Bosch dishwasher? | Fodorite Lounge Forum | Fodor's Travel Talk Forums | This thread | Refback | 05-30-2009 07:07 PM |
| www.elektronik.si :: Poglej temo - Bosch pomivalni stroj | This thread | Refback | 05-24-2009 02:04 AM |
| Bosch Parts and Bosch Repair Help from AppliancePartsPros.com | This thread | Refback | 04-05-2009 09:29 AM |
| www.elektronik.si :: Poglej temo - Bosch pomivalni stroj | This thread | Refback | 02-25-2009 03:37 PM |
| www.elektronik.si :: Poglej temo - Bosch pomivalni stroj | This thread | Refback | 02-25-2009 01:40 PM |
| www.elektronik.si :: Poglej temo - Bosch pomivalni stroj | This thread | Refback | 02-25-2009 12:04 PM |
| Display Modes | |
| freezer coils iced up, trying to troubleshoot | anthonygeier | Refrigerator & Freezer Repair | 6 | 04-14-2008 09:13 AM |
| Dual element or switch troubleshoot | VincentDR | Oven Repair (including Ranges and Cooktops) | 0 | 10-15-2007 05:17 PM |
| Bosch dishwasher | sherryg | Dishwasher Repair | 0 | 10-08-2007 11:46 AM |
| Bosch Dishwasher | JohnM | Dishwasher Repair | 6 | 09-04-2007 09:06 AM |
| Bosch dishwasher | Elise | Dishwasher Repair | 2 | 08-13-2007 07:19 PM |
