Discuss
bosch dishwasher troubleshoot manual
 in
Dishwasher Repair
thank you for posting, german appliance service manuals are hard to come by. Ads By Google
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » bosch dishwasher troubleshoot manual
  #31 (permalink)
Old 01-26-2009, 06:43 PM
Junior Member
Art Vandalay is on a distinguished road
Default thank you
Ads By Google
  #32 (permalink)
Old 02-03-2009, 04:22 PM
Junior Member
rschiffman is on a distinguished road
Default
Thank you so much. I was able to just order the control module front cover to fix those "broken cycles"
  #33 (permalink)
Old 03-06-2009, 03:57 AM
Junior Member
Kara is on a distinguished road
Default Need a Bosch Repair manual for DW246UB
Hello.
I need a repair manual for Bosch unit DW246ub can any tell me where to locate one?
I actually have a Thermador DW246ub and can not even find a repair manual to buy online, it is a 2000 unit dishwasher. One person told me it is the same unit as the Bosch,not having even seen the Bosch dishwasher, I can believe them ,as it has the same numbers.
Please advise is anyone can help?
Thanks,
Kara
  #34 (permalink)
Old 03-06-2009, 08:41 AM
Junior Member
Default Dishwasher manual for bosch dw246ub or thermadordw246ub
Hi Harold,
Thanks I did read your manual and it was helpful in giving me ideas; but it does not have my unit Bosch DW246UB or its sister brand Thermador ( made by Bosch) model #DW246UB( FD-7711-7912)--which is the unit I have.
It seems I can not buy this repair manual anywhere, or even find one online
Do you have any idea where I can find one?
My dishwasher still has a letter f. I wrote a new post today which gives the break down of my problems with this dishwasher.
Hello,
Does any know where I can find a manual for this dishwasher. I am told the Thermador unit is the same as the Bosch DW246ub.
I copied pasted it below
Here is my problem.
Yesterday water came pouring out of the front of my unit. I checked the inside stacking of the dishes, water arms inside the unit were found in good condition with no cracks. I did reposition a large pot and cleared any debris from the screen, and the internal round screen basket. I noticed some un-popped popcorn kernels in the trap before the impeller and I cleaned those out too.
I turned the unit back on and at first everything seem to work okay...then a letter F appeared in my LCD . I looked it up and it seems I have a fill problem. I even placed a gallon of hot water inside the machine to see what it would do; well for a few minutes it worked fine --spraying the water on the upper and lower racks,and then drained from my machine...and would run and run and run and I stopped the machine.
I checked my solder welds in my control unit and all look bright and shiny silver with no burned out marks. I placed it all back together and to no -avail , I get the dreaded letter "F" failed fill mark. I did take the lower panel off and found when the water gushed out it had soaked the sound batting in between my dishwasher door.
I order a new water flow valve today and I am hoping and guessing that this may be the problem--It would be helpful if I could get a repair manual does anyone have one?
Also, if anyone else has any clue what else to do let me know. I am pretty handy as I figured out on my own how to fix the large bearing broken inside the drum of my dryer. I hope I can fix this dishwasher.
Thanks,
Kara
  #35 (permalink)
Old 03-08-2009, 03:24 PM
Junior Member
hunt4trout is on a distinguished road
Default Service Manual
Thanks for posting the manual - any ideas on removing sediment in the dishwasher from the water?
I had to by pass the water filter system due to a leak, our water has high sediment and I think the sediment is clogging the system.
  #36 (permalink)
Old 03-08-2009, 05:00 PM
Junior Member
Default Clogged water flow valve
I would check the water flow valve--There is a screen that could be clogged. If you did want to clean it, then a replacement is around $ 23.95
Goodluck!
Kara
See link:written by Todd below
Bosch 2042 (and others?) fill valve tip - Appliance Blog Repair Forums
wapitiscat
Member
I have a Bosch 2042 that was in the house we bought 8 years ago. I like it even though it's a little small. About 2-3 years ago, the dishes weren't getting clean and I traced the problem to a faulty fill valve. This model is a timed fill only so, if the water flow is restricted, there won't be enough water coming in during the 1 minute fill cycle to adequately clean the dishes. The same symptom occured a few weeks ago and I ordered another fill valve. After removing the water line, I saw that the inlet strainer was clogged with a lot of debris (don't know from where). Anyhow, I suspected that the fill valve was not bad after all. But, since I was in this far and had the replacement part, I went ahead and swapped it out. Now, I proceeded to dismantle the old valve to see how it works and discovered that the inlet strainer can indeed be removed! It takes some very gentle prying with a small screwdriver and patience. Once out, I was able to clean the gunk off. I reassemble the valve and will try it out should the symptom re-appear in the future.
Anyway, I wanted to pass this along because I noticed this same situation (clogged strainer) in my original repair job. I remember trying to get the strainer out but gave up. Perhaps this time around I was braver since I had a new one in hand. Maybe I could have saved some money in the first place. If you have a similar model and the tub ins't filling, 1) it's probably the fill valve and 2) may be just a clogged strainer on the inlet of the valve.
Todd
  #37 (permalink)
Old 03-12-2009, 03:07 PM
Junior Member
PARRISHBOB is on a distinguished road
Default Water retention
I have a SHU3326UC-14. It keeps kicking out the drain cover and leaving water in the bottom. Replaced drain cover and same thing. Any ideas?
  #38 (permalink)
Old 03-21-2009, 07:47 PM
Junior Member
harleyjasondavidson is on a distinguished road
Default thanks
that document had all the info i was going to post questions about! should be able to fix my dishwasher fairly easily now, thanks
  #39 (permalink)
Old 03-29-2009, 03:50 PM
Junior Member
sossend is on a distinguished road
Smile PC Board not fixable
Thanks for posting that manual. I can understand why the mfr doesn't want them out there, but it sure helps the amateur troubleshooter. I found it after I ordered a new control module. I don't think the board was salvagable, it was pretty burnt and pitted. I could have jumpered around the fried area, but it would probably fail again.
  #40 (permalink)
Old 04-03-2009, 12:55 PM
Junior Member
norodnik is on a distinguished road
Default bosch troubleshooting manual
There is mention in this manual, and another manual I found a reference on a one page guide on "Measuring the resistance from the front of any SHU or SHI dishwasher.". All I have been able to find are specific model schematics. I have an SHU 4002/UC. Thanks!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
LinkBacks (?)
LinkBack to this Thread: http://forum.appliancepartspros.com/dishwasher-repair/7123-bosch-dishwasher-troubleshoot-manual.html
Posted By For Type Date
Bosch 2042 (and others?) fill valve tip - ApplianceBlog.com - Appliance Repair Forums This thread Refback 09-17-2009 08:27 AM
www.elektronik.si :: Poglej temo - Bosch pomivalni stroj This thread Refback 09-02-2009 06:27 AM
www.elektronik.si :: Poglej temo - Bosch pomivalni stroj This thread Refback 07-18-2009 10:54 AM
www.elektronik.si :: Poglej temo - Bosch pomivalni stroj This thread Refback 06-29-2009 11:17 PM
Help - does anyone own a Bosch dishwasher? | Fodorite Lounge Forum | Fodor's Travel Talk Forums This thread Refback 05-30-2009 06:07 PM
www.elektronik.si :: Poglej temo - Bosch pomivalni stroj This thread Refback 05-24-2009 01:04 AM
Bosch Parts and Bosch Repair Help from AppliancePartsPros.com This thread Refback 04-05-2009 08:29 AM
www.elektronik.si :: Poglej temo - Bosch pomivalni stroj This thread Refback 02-25-2009 02:37 PM
www.elektronik.si :: Poglej temo - Bosch pomivalni stroj This thread Refback 02-25-2009 12:40 PM
www.elektronik.si :: Poglej temo - Bosch pomivalni stroj This thread Refback 02-25-2009 11:04 AM
Similar Threads
bosch nexxt 500 sevice manual acruzntx Washer Repair 0 04-19-2009 05:08 AM
Need Repair Manual - Bosch HBL755AUC s_m Oven Repair (including Ranges and Cooktops) 1 08-20-2008 03:13 PM
Bosch SHu4306UC Owner's Manual ecowen Dishwasher Repair 2 07-29-2008 03:18 PM
Help how to start to troubleshoot bosch singer123 Dishwasher Repair 1 04-24-2008 08:53 PM
