Discuss
bosch dishwasher troubleshoot manual
 in
Dishwasher Repair
I have an old kenmore ultra wash dishwasher, it stopped working, no water no power to anything, where can I
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » bosch dishwasher troubleshoot manual
  #151 (permalink)
Old 12-12-2015, 12:01 PM
Junior Member
ceramicmaker is on a distinguished road
Default
I have an old kenmore ultra wash dishwasher, it stopped working, no water no power to anything, where can I find the fuse for this, sorry model unknown. the door locks ok, but no power, so I am sure it has to be a fuse.
  #152 (permalink)
Old 01-26-2016, 09:39 AM
Junior Member
marlont is on a distinguished road
Default
Great Share!...If you misplace your original manual or bought the appliance used, it can be a time intensive task to find the appliance service manual online.
  #153 (permalink)
Old 01-28-2016, 11:18 AM
Junior Member
mkayi is on a distinguished road
Thumbs up Thank you!
Thank you for sharing this troubleshooting manual!
  #154 (permalink)
Old 03-03-2016, 10:18 PM
Junior Member
Sakura Appliance Repair is on a distinguished road
Default dishwasher
we can help
Appliance
  #155 (permalink)
Old 04-21-2016, 09:49 AM
Junior Member
gteasley is on a distinguished road
Default
Does anyone know about a bosh model # shx46a It will not drain. Can I test for this before ordering parts
  #156 (permalink)
Old 03-24-2017, 09:47 AM
Junior Member
bcollinge is on a distinguished road
Default
This is great, thanks!
  #157 (permalink)
Old 04-10-2017, 10:51 PM
Junior Member
jamesgluten is on a distinguished road
Default hey, your problem is solved
Hey, i see you are facing a lot of problem due to your dishwasher..Well i have the solution to your problem i found this link on internet..really a helping article Bosch Dishwasher Error Codes: E15, E22, E01, E09 | Error Codes Pro . You can find your solution here.
  #158 (permalink)
Old 04-11-2017, 11:09 PM
kli kli is offline
Junior Member
kli is on a distinguished road
Default
Quote:
Originally Posted by jeremydfaust View Post
Hi, Thanks for the info. My 2006 SHE45 had the heater prong burnt out in the control module as did most of the models in this thread. I'd like to report that all is working great with the rather quick and painless repair.
Thanks again.
Burnt in Buffalo
I'm having a similar issue with my she45m05uc/50. Based on the symptoms (abnormally long runs, lukewarm wash etc) it seems like it could be a burnt out solder joint connection. Unfortunately I got as far as the control panel cover. I was able to partially open it, but the design is different than what is mentioned in this thread and in the guide i followed below. One side of it doesn't even appear to be able to open despite the back being hinged. I'm afraid of using any more force than I already have for fear of breaking the cover.
Through the portion i was able to open, i was able to view most of the board. As far as I could tell, I couldn't see any damaged connections. However, I can't be 100% certain. Does anyone have any advice on how to open my particular model's cover? Or thoughts on possible other causes of what is happening?
Thanks,
Kelvin
Oh, also the Error Code I get when hitting the 2 mode buttons + Power is: C6
I haven't come across what that means.
Bosch SHU43 Dishwasher Repair - Dishwasher keeps running (Stuff)
  #159 (permalink)
Old 04-12-2017, 08:57 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Very likely you would need to remove the outer door panel fist. Try to follow the instructions from attached file.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #160 (permalink)
Old 04-13-2017, 09:16 AM
kli kli is offline
Junior Member
Default
Quote:
Hi Gene -
Thanks for the reply!
I actually did remove the outer door panel as well as separating the fascia console from the frame. However I there were no tabs as far as I could tell that would allow me to separate the control module from the frame. And I was unable to open the control module cover completely, as one side of it didn't even appear to have an opening all the way around.
I will try to post some pictures when I get home tonight.
Any thoughts on what the code C6 means?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
LinkBacks (?)
LinkBack to this Thread: http://forum.appliancepartspros.com/dishwasher-repair/7123-bosch-dishwasher-troubleshoot-manual.html
Posted By For Type Date
Bosch 2042 (and others?) fill valve tip - ApplianceBlog.com - Appliance Repair Forums This thread Refback 09-17-2009 08:27 AM
www.elektronik.si :: Poglej temo - Bosch pomivalni stroj This thread Refback 09-02-2009 06:27 AM
www.elektronik.si :: Poglej temo - Bosch pomivalni stroj This thread Refback 07-18-2009 10:54 AM
www.elektronik.si :: Poglej temo - Bosch pomivalni stroj This thread Refback 06-29-2009 11:17 PM
Help - does anyone own a Bosch dishwasher? | Fodorite Lounge Forum | Fodor's Travel Talk Forums This thread Refback 05-30-2009 06:07 PM
www.elektronik.si :: Poglej temo - Bosch pomivalni stroj This thread Refback 05-24-2009 01:04 AM
Bosch Parts and Bosch Repair Help from AppliancePartsPros.com This thread Refback 04-05-2009 08:29 AM
www.elektronik.si :: Poglej temo - Bosch pomivalni stroj This thread Refback 02-25-2009 02:37 PM
www.elektronik.si :: Poglej temo - Bosch pomivalni stroj This thread Refback 02-25-2009 12:40 PM
www.elektronik.si :: Poglej temo - Bosch pomivalni stroj This thread Refback 02-25-2009 11:04 AM
Similar Threads
bosch nexxt 500 sevice manual acruzntx Washer Repair 0 04-19-2009 05:08 AM
Need Repair Manual - Bosch HBL755AUC s_m Oven Repair (including Ranges and Cooktops) 1 08-20-2008 03:13 PM
Bosch SHu4306UC Owner's Manual ecowen Dishwasher Repair 2 07-29-2008 03:18 PM
Help how to start to troubleshoot bosch singer123 Dishwasher Repair 1 04-24-2008 08:53 PM
