Discuss
bosch dishwasher troubleshoot manual
 in
Dishwasher Repair
Harold Thanks for sharing the manual, it is really going to be helpful. DarS
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » bosch dishwasher troubleshoot manual
  #141 (permalink)
Old 01-27-2014, 03:22 PM
Junior Member
DarS is on a distinguished road
Default
Harold
DarS
  #142 (permalink)
Old 02-27-2014, 09:35 PM
Junior Member
markonah is on a distinguished road
Default
Thanks for sharing the manual...
  #143 (permalink)
Old 03-12-2014, 06:32 AM
Junior Member
Default
Repairs went well. Dishwasher is washing and the sun is shinning again. The manual was outstanding and thanks again Harold.
Dar Schulze
  #144 (permalink)
Old 04-05-2014, 04:30 PM
Junior Member
arstb is on a distinguished road
Default
Wow Harold!!
I had been searching for this particular Bosch manual for quite sometime, until now, and this manual totally saved my ass today! Thank you so much!!!
I just love this community!
  #145 (permalink)
Old 09-25-2014, 01:41 PM
Junior Member
Wevvie is on a distinguished road
Default Bosch? I think not
I married into a Bosch dishwasher after installing three Kenmore middle-priced models for myself, my daughter and my dad. All had food digesters (basically a garbage disposal at the bottom).
This Bosch had been a disappointment. I know they are highly regarded by CR, but way too many dishes not cleaned.
My wife says I need to clean them before putting them into the dishwasher. Doesn't that defeat the purpose? My Kenmores all cleaned much better than the Bosch, which I maintain regularly to assure the micro-screen is clean.
  #146 (permalink)
Old 11-26-2014, 06:47 PM
Junior Member
Leo Ladzinske is on a distinguished road
Default
Quote:
Originally Posted by tjwright View Post
Harold,
I have tried to open the pdf file but I get an error message telling me the file has an error and cannot be repaired. Can you email me a copy? tj@wrighthouse.us
Thx TJ
Harold,
Have you seen a manual for Bosch SHU43C05UC/43. I have a similar problem where water remains in the bottom of our dishwasher. My e-mail address is leoladzinske@att.net. Your help is appreciated.
  #147 (permalink)
Old 02-09-2015, 10:07 AM
Junior Member
Jimbo Bigbelly is on a distinguished road
Default Micro Filter Basket Assembly Design Problem
Great thread. Don't know if this is the correct thread for this post, but I guess someone could move it as necessary.
Wevvie's post is very accurate. With no grinder, bits of food, seeds etc can go through the Micro Filter Basket entering the pump, and potentially damaging the impeller. If the stuff gets through the pump, the seeds etc can end up in the spinning washers, clogging the little holes. This can stop the spinners from spinning and severely affect the D/W cleaning.
The design problem of the Micro Filter Basket is obvious. Look down the center of the top, and you will see some baffles. Take a small seed or BB and drop it in, shake it a little, and the seed/BB drops out the bottom. The micro filtration is worthless. Stuff that floats can go over the edge of that raised plastic baffle and fall straight down into the sump area.
To fix the design problem, go to home depot and buy a rubber stopper like we used to use in bathtubs back in the day, and force it down into the center of the Micro Filter Basket Assembly until it covers all those holes you see at the top. I had to trim mine with a razor blade. This will prevent the seeds from getting down into the sump area and into the pump, and into the spinners.
Now of course you have to remove the spinners and clean them out. This debris could also be the cause of some of the odors you may be experiencing.
  #148 (permalink)
Old 02-09-2015, 10:17 AM
Junior Member
Default
Hi, SamirD! I have seen this problem caused by the lack of a dishwasher air gap and by the air gap being clogged. If you have an air gap mounted to the sink, spin off the top and clean it out. If you don't have an air gap, get one. :-)> I looked at appliancepartpros but couldn't find one but Home Depot carries them, see
PartsmasterPro Dishwasher Air Gap with Stainless Steel Cover-58600 - The Home Depot
  #149 (permalink)
Old 04-10-2015, 06:42 AM
Junior Member
mcneil christian is on a distinguished road
Default
Thanks for sharing such useful information.
  #150 (permalink)
Old 12-12-2015, 11:52 AM
Junior Member
ceramicmaker is on a distinguished road
Default
my dish washer has stop, and the control panle does not light up
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
LinkBacks (?)
LinkBack to this Thread: http://forum.appliancepartspros.com/dishwasher-repair/7123-bosch-dishwasher-troubleshoot-manual.html
Posted By For Type Date
Bosch 2042 (and others?) fill valve tip - ApplianceBlog.com - Appliance Repair Forums This thread Refback 09-17-2009 08:27 AM
www.elektronik.si :: Poglej temo - Bosch pomivalni stroj This thread Refback 09-02-2009 06:27 AM
www.elektronik.si :: Poglej temo - Bosch pomivalni stroj This thread Refback 07-18-2009 10:54 AM
www.elektronik.si :: Poglej temo - Bosch pomivalni stroj This thread Refback 06-29-2009 11:17 PM
Help - does anyone own a Bosch dishwasher? | Fodorite Lounge Forum | Fodor's Travel Talk Forums This thread Refback 05-30-2009 06:07 PM
www.elektronik.si :: Poglej temo - Bosch pomivalni stroj This thread Refback 05-24-2009 01:04 AM
Bosch Parts and Bosch Repair Help from AppliancePartsPros.com This thread Refback 04-05-2009 08:29 AM
www.elektronik.si :: Poglej temo - Bosch pomivalni stroj This thread Refback 02-25-2009 02:37 PM
www.elektronik.si :: Poglej temo - Bosch pomivalni stroj This thread Refback 02-25-2009 12:40 PM
www.elektronik.si :: Poglej temo - Bosch pomivalni stroj This thread Refback 02-25-2009 11:04 AM
Similar Threads
bosch nexxt 500 sevice manual acruzntx Washer Repair 0 04-19-2009 05:08 AM
Need Repair Manual - Bosch HBL755AUC s_m Oven Repair (including Ranges and Cooktops) 1 08-20-2008 03:13 PM
Bosch SHu4306UC Owner's Manual ecowen Dishwasher Repair 2 07-29-2008 03:18 PM
Help how to start to troubleshoot bosch singer123 Dishwasher Repair 1 04-24-2008 08:53 PM
