Discuss
bosch dishwasher troubleshoot manual
 in
Dishwasher Repair
Ed, Yes, disconnect the water line. Make sure the water supply is turned off. Possible you will need to pull
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » bosch dishwasher troubleshoot manual
  #91 (permalink)
Old 01-27-2011, 02:18 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Ed,
Possible you will need to pull the dishwasher out of the cabinet to ease the side access.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #92 (permalink)
Old 01-28-2011, 10:02 AM
Junior Member
Ed Y is on a distinguished road
Default
Quote:
Originally Posted by Gene View Post
Ed,
Thanks a lot. I'll let you know how I make out as soon as the valve arrives.
Ed Y
  #93 (permalink)
Old 02-01-2011, 03:16 PM
Junior Member
Default
Quote:
Ed Y
Gene,
Thanks for the tips. The valve arrived the other day and I installed it today. The first time that I reassembled it, I had dropped the small washer that seals between the plastic of the valve and the elbow of the water supply, but I caught my error prior to turning the water on. Everything turned out great, for a change. Your help made me a hero in my house.
Maybe I should get cards printed up and go in the appliance repair business, Just kidding.
Ed Y
I probably could have used a "faucet wrench" to remove the water supply elbow and thus eliminated the need to pull the washer out from the cabinet.
  #94 (permalink)
Old 02-01-2011, 04:40 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You are welcome Ed. I'm glad you were able to fix it.
Thank you for the feedback.
__________________
  #95 (permalink)
Old 02-21-2011, 03:59 PM
Junior Member
Geokav is on a distinguished road
Red face Bosch manual
Thank you for the lead. I've been able to narrow down the possibilities although I'm not certain the manual is written for the SHU6605C. The fault code came up as '2' (heater) and the water was indeed cool. The main symptom I have is weak water flow into the tank. The pump motor is working and drawing about 1.4A.
  #96 (permalink)
Old 02-21-2011, 05:01 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You may want to inspect the control module for a broken solder joint. This issue is much more common than a fault heater.
The model number you posted does not come up. Is it American model?
__________________
  #97 (permalink)
Old 02-21-2011, 08:22 PM
Junior Member
Red face
Thanks Gene,
Yes, the tag says made in U.S.A.
Bosch model #SHU66C05UC/23
I put away my tools for the night. whew!
I'll try locating and checking the controller joints. I still haven't determined why the water isn't pumping with force. I expect I'll need to renove the pump and inspect its 'innards'. i nust adnit I'm more at home with commercial HVAC than I am with appliances. This is a first with dishwashers!
  #98 (permalink)
Old 02-21-2011, 10:13 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Earlier you said: "I have is weak water flow into the tank". Now you stating that "the water isn't pumping with force". So what exactly is wrong? Might be the water inlet valve is clogged?
How much water is inside the dishwasher?
- The water inlet valve Part number: AP3783031
- The control module Part number: AP3874051
__________________
  #99 (permalink)
Old 02-26-2011, 09:29 PM
Member
Applianceaid is on a distinguished road
Default Bosch Dishwasher No Drain Repair Video
Hey all, I found a really good video online, it explains what is wrong and how to fix a bosch dishwasher that wont drain.
Click on the link below.
Bosch DW Repair Video
  #100 (permalink)
Old 02-27-2011, 11:23 AM
Junior Member
Default gave up
Thank you for the input. I accepted defeat and have an appt with a service tech. This one's going to the professionals; not being a Dr. I have no' patience' for this!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
LinkBacks (?)
LinkBack to this Thread: http://forum.appliancepartspros.com/dishwasher-repair/7123-bosch-dishwasher-troubleshoot-manual.html
Posted By For Type Date
Bosch 2042 (and others?) fill valve tip - ApplianceBlog.com - Appliance Repair Forums This thread Refback 09-17-2009 09:27 AM
www.elektronik.si :: Poglej temo - Bosch pomivalni stroj This thread Refback 09-02-2009 07:27 AM
www.elektronik.si :: Poglej temo - Bosch pomivalni stroj This thread Refback 07-18-2009 11:54 AM
www.elektronik.si :: Poglej temo - Bosch pomivalni stroj This thread Refback 06-30-2009 12:17 AM
Help - does anyone own a Bosch dishwasher? | Fodorite Lounge Forum | Fodor's Travel Talk Forums This thread Refback 05-30-2009 07:07 PM
www.elektronik.si :: Poglej temo - Bosch pomivalni stroj This thread Refback 05-24-2009 02:04 AM
Bosch Parts and Bosch Repair Help from AppliancePartsPros.com This thread Refback 04-05-2009 09:29 AM
www.elektronik.si :: Poglej temo - Bosch pomivalni stroj This thread Refback 02-25-2009 03:37 PM
www.elektronik.si :: Poglej temo - Bosch pomivalni stroj This thread Refback 02-25-2009 01:40 PM
www.elektronik.si :: Poglej temo - Bosch pomivalni stroj This thread Refback 02-25-2009 12:04 PM
Similar Threads
bosch nexxt 500 sevice manual acruzntx Washer Repair 0 04-19-2009 06:08 AM
Need Repair Manual - Bosch HBL755AUC s_m Oven Repair (including Ranges and Cooktops) 1 08-20-2008 04:13 PM
Bosch SHu4306UC Owner's Manual ecowen Dishwasher Repair 2 07-29-2008 04:18 PM
Help how to start to troubleshoot bosch singer123 Dishwasher Repair 1 04-24-2008 09:53 PM
