| » WP Dishwasher Starts When Door Is Closed...... |
Model Number: GU940SCGB3 Brand: Whirlpool Age: 5 - 10 years
I am having problems with a Whirlpool dishwasher, it starts all by itself when I close the door. Another problem is it works intermittently when selecting a cycle, sometimes China cycle or Normal. Any help very much appreciated. Thank you.
Mike Ads By Google Related Models |
Replacement parts for WHIRLPOOL GU940SCGB3 | AppliancePartsPros.com Here is the tech sheet http://www.servicematters.com/docs/w...%208051291.pdf This is going to be a crap shoot. It is probably either the keyboard or the control board. Unfortunately I cannot find a keypad switch diagram which would have let you check it with a meter. Since the unit has a stuck key error (light flashes), see the tech sheet, my guess would be that the control board is the problem.
__________________
Yes it could. I would check it visually though I doubt you will find anything.
As I said if the start button was shorted (always closed) it should give an error as per the data sheet. You could try the following but it is a long shot as the cleaning can fix an open connection and I doubt that is your problem. Connector Cleaning / Checking Unplug the unit Open it up Remove the ribbon cable from the keypad to the control board at the control board. Clean the edge connector. If it is the type where there is not a connector just the insulation is removed, it can be cleaned with a pencil eraser. Do not use an ink eraser as it is too abrasive. Check the tracks in the ribbon cable for hairline cracks. A magnifying glass helps here. Would not hurt to clean the connector on the board. Use electronics contact cleaner or isopropyl alcohol and a tooth brush. Be gentle and do not reconnect till all the solvent evaporates. Reconnect everything and give it a try.
__________________
I'm experiencing the same troubles, was replacing the control board the trick? The machine runs on it's own, certain buttons are starting to not work, the machine stops mid cycle and needs to be restarted. All sorts of weird happenings.
Thanks for any help that can be provided. Same machine and model: gu940scgb3 |
| Display Modes | |
| GE Adora Fridge: Door alarm triggers even when door closed | lighthouse832 | Refrigerator & Freezer Repair | 1 | 01-08-2010 12:23 AM |
| Dishwasher door leaks only as it is being closed. | john.augustine | Dishwasher Repair | 3 | 11-19-2009 03:02 AM |
| dishwasher door wont stay closed | kspence | Dishwasher Repair | 1 | 10-12-2009 12:36 PM |
| Dryer starts when door closed without pressing start | mightymoe | Dryer Repair | 1 | 10-26-2008 04:50 PM |
| Gas dryer starts when door is closed | DonnySchepp | Dryer Repair | 8 | 06-22-2008 12:31 PM |
