Discuss
Admiral dishwasher noise
 in
Dishwasher Repair
I have an admiral dishwasher makeing a lot of noise when i first start and at the point of dumping
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Admiral dishwasher noise
  #1 (permalink)
Old 04-07-2008, 03:05 PM
Junior Member
repair man is on a distinguished road
Unhappy Admiral dishwasher noise
Brand: Admiral   Age: 1 - 5 years
I have an admiral dishwasher makeing a lot of noise when i first start and at the point of dumping water . Thought it might be comeing from main motor but am starting to wonder if it is comeing from drain pump. Pulled drain pump apart and did not see anything in it or loose. Tryed to pull main motor out takeing the 5 screws out of the lower water spinner and than a single screw that held in a small water circulater and them the three screws under the main motor but was unable to still get the pump out. Boy do i need some help!
Ads By Google
  #2 (permalink)
Old 04-08-2008, 09:15 AM
Junior Member
Talking Solved and fixed
After pulling the dish washer out a half dozen times i solved the problem . seems a small piece of plastic went thru the dish washer and was creating problems along the way.First at the motor which was causeing it to stop and them later at the pump. re moved THE PIECE LAST NIGHT AND ALL IS FINE.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Admiral Dryer LNC7753A71 make noise wintery Dryer Repair 2 11-03-2009 08:14 PM
admiral dishwasher slsanders Dishwasher Repair 1 10-25-2009 05:38 AM
admiral washer making gear loud noise when spinning or aggitating? heidmann1 Washer Repair 3 10-02-2009 04:41 PM
Admiral washer stops just before rinse, makes loud screaming noise fharris5 Washer Repair 1 11-24-2008 02:03 PM
Admiral makes growling noise nextleft Washer Repair 0 01-14-2008 01:45 PM
