Discuss
Bosch dishwasher question
 in
Dishwasher Repair
My Bosch dishwasher in the past week has started running for a very long time. Water is not draining out,
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Bosch dishwasher question
  #1 (permalink)
Old 01-18-2010, 06:29 PM
Junior Member
aelst is on a distinguished road
Default Bosch dishwasher question
Model Number: she42l12uc   Brand: Bosch   Age: 1 - 5 years
My Bosch dishwasher in the past week has started running for a very long time. Water is not draining out, apparently during the rinse cycle. The problem does not seem to be a clogged pipe because when I hit the "cancel drain" buttons, the water quickly drains out of the dishwasher. Any advice?
Related Models
Whirlpool SHF3801W0 Dishwasher
Whirlpool SHF3804W2 Dishwasher
Whirlpool SHF4500W0 Dishwasher
Whirlpool SHF5500W0 Dishwasher
Whirlpool SHF5501W0 Dishwasher
Whirlpool SHF5504W0 Dishwasher
Whirlpool SHF5584P1 Dishwasher
Whirlpool SHF5584P2 Dishwasher
Whirlpool SHF5801W0 Dishwasher
Whirlpool SHF5801W1 Dishwasher
Whirlpool SHF5884P1 Dishwasher
Whirlpool SHF5884P2 Dishwasher
Whirlpool SHF7800W0 Dishwasher
Whirlpool SHF7801W0 Dishwasher
Whirlpool SHF7804W1 Dishwasher
Whirlpool SHF7884P0 Dishwasher
Whirlpool SHF7884P1 Dishwasher
Whirlpool SHF7884P2 Dishwasher
Bosch SHI4302 UC/06 -FD8002
Bosch SHI4302 UC/11 -FD8003
Bosch SHI4302 UC/12
Bosch SHI4306 UC/06 -FD8002
Bosch SHI4306 UC/11 -FD8003
Bosch SHI4306 UC/12
Bosch SHI66A05 UC/14 (FD 8211-)
Bosch SHI6802 UC/06
Bosch SHI6802 UC/11
Bosch SHI6802 UC/12
Bosch SHI6805 UC/06
Bosch SHI6805 UC/11
Bosch SHI6805 UC/12
Bosch SHI6806 UC/06
Bosch SHI6806 UC/11
Bosch SHI6806 UC/12
Whirlpool SHU30011 DISHWASHER
Bosch SHU3002
Whirlpool SHU30041 DISHWASHER
Bosch SHU3006
Bosch SHU3012
Whirlpool SHU30140 DISHWASHER
Whirlpool SHU30141 DISHWASHER
Bosch SHU3016
Bosch SHU3032 UC/06 (FD 7908-8002)
Bosch SHU3032 UC/11 (FD 8002-8003)
Bosch SHU3032 UC/12 (FD 8003-)
Bosch SHU3035 UC/12 (FD 8006-)
Bosch SHU3036 UC/06 (FD 7908-8002)
Bosch SHU3036 UC/11 (FD 8002-8003)
Bosch SHU3036 UC/12 (FD 8003-)
Bosch SHU3132 UC/12 (FD 8105-)
Bosch SHU3135 UC/12 (FD 8105-)
Bosch SHU3136 UC/12 (FD 8105-)
Bosch SHU3302 UC/06 (FD 7902-8003)
Bosch SHU3302 UC/11 (FD 8003-8003)
Bosch SHU3302 UC/12 (FD 8003 -)
Bosch SHU3305 UC/06 (FD 7902-8003)
Bosch SHU3305 UC/11 (FD 8003-8003)
Bosch SHU3305 UC/12 (FD 8003 -)
Bosch SHU3306 UC/06 (FD 7902-8003)
Bosch SHU3306 UC/11 (FD 8003-8003)
Bosch SHU3306 UC/12 (FD 8003 -)
Bosch SHU3307 UC/12 (FD 8005 -)
Bosch SHU3322 UC/06
Bosch SHU3322 UC/11
Bosch SHU3322 UC/12
Bosch SHU3322 UC/12 (FD 8003-)
Bosch SHU3326 UC/06
Bosch SHU3326 UC/11
Bosch SHU3326 UC/12
Bosch SHU3326 UC/12 (FD 8003-)
Bosch SHU3336 UC/06
Bosch SHU3336 UC/11
Bosch SHU3336 UC/12
Bosch SHU3336 UC/12 (FD 8003-)
Bosch SHU33A02 UC/14 (FD 8211-)
Bosch SHU33A06 UC/14 (FD 8211-)
Bosch SHU33AC02 UC/14
Bosch SHU33AC06 UC/14
Whirlpool SHU40011 DISHWASHER
Bosch SHU4002 UC/06
Whirlpool SHU40041 DISHWASHER
Bosch SHU4006 UC/06
Bosch SHU4016 UC/06
Bosch SHU4022 UC/06
Bosch SHU4026 UC/06
Bosch SHU4036 UC/06
Bosch SHU4302 UC/06 (FD 7705-7912)
Bosch SHU4302 UC/11 (FD 8001-8003)
Bosch SHU4302 UC/12 (FD 8003-)
Bosch SHU4306 UC/06 (FD 7705-7912)
Bosch SHU4306 UC/11 (FD 8001-8003)
Bosch SHU4306 UC/12 (FD 8003-)
Bosch SHU4312 UC/06 (FD 7701-7912)
Bosch SHU4312 UC/11 (FD 8001-8003)
Bosch SHU4312 UC/12 (FD 8003-)
Bosch SHU4316 UC/06
Bosch SHU4316 UC/11
Bosch SHU4316 UC/12
Bosch SHU4322 UC/12
Bosch SHU4322 UC/12 (FD 8003-)
Bosch SHU4326 UC/12
Bosch SHU4326 UC/12 (FD 8003-)
Bosch SHU43C02 UC/14 (FD 8211-)
Bosch SHU43C05 UC/14 (FD 8211-)
Bosch SHU43C06 UC/14 (FD 8211-)
Bosch SHU43C07 UC/14 (FD 8211-)
Bosch SHU43E02 UC/14 (FD 8211-)
Bosch SHU43E05 UC/14 (FD 8211-)
Bosch SHU43E06 UC/14 (FD 8211-)
Bosch SHU43E07 UC/14 (FD 8211-)
Whirlpool SHU45010 Dishwasher
Whirlpool SHU45020 Dishwasher
Whirlpool SHU50041 Dishwasher
Whirlpool SHU50043 Dishwasher
Bosch SHU5302 UC/06 (FD 7705-7912)
Bosch SHU5302 UC/11 (FD 8001-8003)
Bosch SHU5302 UC/12 (FD 8003-)
Bosch SHU5304 UC/06 (FD 7705-7912)
Bosch SHU5304 UC/11 (FD 8001-8003)
Bosch SHU5304 UC/12 (FD 8003-)
  #2 (permalink)
Old 01-25-2010, 11:18 AM
Junior Member
roadworrier is on a distinguished road
Default Bosch SHV4303UC/U11 FD8003 not draining.
I have the same problem.
The dishwasher fills, washes and heats OK but will not drain. I can get the pair of flashing lights which set up the test sequence but pushing the two buttons a second time to actually start the test has no effect.
I have measured the drain motor resistance at 10.5 ohms (should be 16.5 according to manual - shorted turns?). There is no sign of voltage at the pump at any stage in the program. The drain is clear of any obstruction.
I suspect the control module is damaged but I'm reluctant to put in a new one if there is an existing pump motor fault which will damage it as well.
I'm going abroad for some time shortly and my Julia Child will be unimpressed if I can't get it going for her soon!
Any advice would be very welcome.
  #3 (permalink)
Old 04-14-2010, 06:13 PM
Junior Member
bstadtherr is on a distinguished road
Default Bosch not draining
Anyone have ideas here? I'm having trouble and I'm at my wits end. Checked the hose. Checked the drain. Ran the diagnostics. Watched it through complete cycles (it tends to work correctly when I'm watching) but it will not drain at the end of the cycle. I can drain it manually and it empties fine. Finally out of desperation I replaced the drain pump and the fill/flow sensors. Still same result. It drains manually but always has water in it at the end of the cycle.
  #4 (permalink)
Old 04-14-2010, 07:00 PM
Junior Member
Default Bosch Dishwasher Problem
Subsequent to my posting I found (embarrassingly) a mechanical blockage but not before I had invested in a brand new control unit - which I hope I will never need now.
If you post your exact model number and this unit is the right one we may be able to reach and arrangement. The control unit is in Orange Ca.
Roadworrier
  #5 (permalink)
Old 05-15-2010, 06:26 PM
Junior Member
Default
I have an SHU66C06 and the control unit is AP2834006
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
bosch dishwasher-follow up question for Gene AReed Dishwasher Repair 1 01-16-2010 02:53 PM
Dishwasher question TonyTan Dishwasher Repair 0 06-24-2009 05:57 AM
Bosch repair question glpera Dishwasher Repair 0 05-14-2009 04:38 PM
Dishwasher Question como Dishwasher Repair 1 04-22-2009 02:01 AM
Bosch Propane Question Mike Larry Oven Repair (including Ranges and Cooktops) 1 12-16-2008 06:27 PM
