florida
#1 Posted : Monday, January 18, 2010 4:11:11 PM(UTC)
florida
The motor won't run. Test shows motor low current. Motor windings show ok. Which would be the most possable: the washer control electronic card or the thermsistor?
#2 Posted : Tuesday, January 19, 2010 12:29:51 AM(UTC)
Here are your parts includes the wiring diagram
Replacement parts for MAYTAG MDB7130AWW Dishwasher - Undercounter | AppliancePartsPros.com
I cannot find technical info on this unit.
[COLOR="Blue"]
The motor won't run. Test shows motor low current. Motor windings show ok.[/COLOR]
I am assuming you checked the windings with a meter.
[COLOR="Blue"]Which would be the most possable: the washer control electronic card or the thermsistor?[/COLOR]
The thermistor should not effect the motor, it is just temperature sensing.
Could be the control board or the motor.
I am assuming that you have checked the motor and it rotates freely.
I would do a live test.
If the wash and main windings are getting 120 volts when they should then the motor is the probable cause.
Just be very very careful. 120 volts shouldn't kill you but when you yank your hand back odds are you will loose some skin !!
Also I have you checked the winding's resistance to it's case.
It is possible that one of them has shorted to the case and this blew the board.
Maytag Performance Dishwaher (Dishwasher Repair)
by hager12 Today at 11:34:48 AM(UTC)
HELP!!! Maytag Lat9604abe leaking from weeping holes in tub seal (Washer Repair)
by gocanada72 Today at 5:53:29 AM(UTC)
Maytag electric dryer model LDE9306ACE (Dryer Repair)
by Guest 3/7/2024 9:11:14 AM(UTC)
maytag top loader from 2020 mvwc465hw2 (Washer Repair)
by Scott in Ohio 3/4/2024 8:44:04 AM(UTC)
Maytag Bravos clicking when filling, wash plate spins fast afterward (Washer Repair)
by nsar24 3/3/2024 9:34:39 AM(UTC)
Maytag Bravos XL MCT Thrust washer (Washer Repair)
by EricP 2/21/2024 2:57:06 PM(UTC)
Maytag Bravos MCT Washer (Washer Repair)
by Guest 2/21/2024 12:53:32 PM(UTC)
Maytag Refrigerator freezing food on lowest setting (Refrigerator & Freezer Repair)
by ilgy 2/15/2024 8:14:17 AM(UTC)
Maytag Maxiima mhn5100dw (Washer Repair)
by Shawn Griffin 2/14/2024 3:45:10 PM(UTC)
Maytag MVW7232HW0 Will Not Complete a Cycle (Washer Repair)
by JNN1988 2/7/2024 8:29:57 AM(UTC)
Maytag Electric dryer model MEDC300XW0 (Dryer Repair)
by Guest 2/6/2024 1:56:33 PM(UTC)
Maytag Washer Doesn't Complete Spin Cycle (Washer Repair)
by glmoore0001 2/5/2024 6:32:24 AM(UTC)
Maytag dishwasher model MDB4949SKZ1 (Dishwasher Repair)
by thepontif 2/3/2024 11:15:46 AM(UTC)
Maytag high pitch squeal during spin (Washer Repair)
by Guest 2/1/2024 4:09:33 PM(UTC)
Maytag topload agitator (Washer Repair)
by Guest 1/30/2024 7:23:54 AM(UTC)
