Discuss
maytag dishwasher stops cycle starts clicking
 in
Dishwasher Repair
My dishwasher starts up with no problem and runs for about 20 minutes and then starts clicking at the same
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » maytag dishwasher stops cycle starts clicking
  #1 (permalink)
Old 04-06-2008, 12:01 PM
rainbow rainbow is offline
Junior Member
rainbow is on a distinguished road
Default maytag dishwasher stops cycle starts clicking
Model Number: MDB9150AWB   Brand: Maytag   Age: 1 - 5 years
My dishwasher starts up with no problem and runs for about 20 minutes and then starts clicking at the same time every time and will not finish cycle regardless of which buttons i press. Any suggestions (contoller or float or other)?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 04-06-2008, 12:04 PM
Junior Member
Default
any advise from maytag users
  #3 (permalink)
Old 04-07-2008, 11:59 AM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Where this clicking is coming from - the control panel or the bottom of the dishwasher?
__________________
Professional appliance repair in Los Angeles, California.
  #4 (permalink)
Old 04-07-2008, 02:12 PM
Junior Member
Default
The clicking is coming from the control panel. The number flicks on and off with the clicking.
  #5 (permalink)
Old 04-07-2008, 02:20 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The first thing I would do is replace the electronic control.
- The part number for the control assembly is AP3158622
Here are the break down diagrams for the Maytag dishwasher Model MDB9150AWB
__________________
  #6 (permalink)
Old 04-08-2008, 09:13 PM
BeginnerGuy BeginnerGuy is offline
Junior Member
BeginnerGuy is on a distinguished road
Default
I have a Maytag MDB9150AWW...similar model. The control board died about a week ago. I didn't have any clicking...I've posted elsewhere in the forum if interested.
If it is clicking in the upper door, I'd check to make sure the switches on the latch assembly are working. Just a thought.
Installing a control board isn't to difficult. I finished putting one in tonight. 1st, make sure power is turned off. Next, make a picture of where the wires plug in before you remove the defective board. This should be helpful when putting the new board in.
Based on suggestions from others, check the wiring harness for defects. I found that there were a couple of wires where the plastic sheathing was cut through, but the copper wire looked unharmed. I found this down where the door hinges. It looked like a metal part from the door had been cutting into the wires somewhat. I'm not sure if this is what caused the control board to fail. Anyway, I used some electrical tape to tape up the wires, and then also to cover up and sharp metal edges.
  #7 (permalink)
Old 04-08-2008, 09:20 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Thank you BeginnerGuy,
Very useful advise.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
washer starts clicking when going to different cycle hotdeal1957 Washer Repair 2 03-21-2008 12:45 AM
Maytag Neptune starts then stops in 5 sec EddieM Washer Repair 3 02-16-2008 10:38 AM
Dishwasher starts, then stops mmoody Dishwasher Repair 0 01-13-2008 07:20 AM
Clicking noise when spin cycle starts Daniel Fox Washer Repair 0 11-04-2007 02:25 PM
Starts to pump during wash then shuts down, starts, stops real quidk sirgalagit Dishwasher Repair 1 10-03-2007 09:23 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
