Spark208v
#1 Posted : Sunday, January 17, 2010 10:29:47 AM(UTC)
Spark208v
Replaced detergent and rinse dispensor. Simple process I thought. now, when i select wash options, the LED lights light up. when I select start button, the dishwasher wont start. what is my next trouble shooting item and is there a trouble shooting manual?
#2 Posted : Monday, January 18, 2010 1:33:00 AM(UTC)
Control panel parts replacement parts for WHIRLPOOL KUDS01FLSS1 Undercounter Dishwasher | AppliancePartsPros.com
Here is a tech sheet
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208537797.pdf
[COLOR="Blue"]now, when i select wash options, the LED lights light up.[/COLOR]
When you say the LED lights up I assume you mean the correct one lights.
[COLOR="Blue"]when I select start button, the dishwasher wont start.[/COLOR]
Could be you just knocked a connection off or loose.
Unplug , check and re-seat all connectors.
Check that the door switch closes properly.
It is possible that some dirt got in the keypad connection.
Connector Cleaning / Checking
Unplug the unit
Open it up
Remove the ribbon cable from the keypad to the control board at the control board.
Clean the edge connector.
If it is the type where there is not a connector just the insulation is removed, it can be cleaned with a pencil eraser. Do not use an ink eraser as it is too abrasive.
Check the tracks in the ribbon cable for hairline cracks. A magnifying glass helps here.
Would not hurt to clean the connector on the board. Use electronics contact cleaner or isopropyl alcohol and a tooth brush. Be gentle and do not reconnect till all the solvent evaporates.
Reconnect everything and give it a try.
If this does nothing check that the start switch output from the keypad is OK, see the tech sheet.
DLGX8001W gas dryer clicks on control board but wont start (Dryer Repair)
by Guest 3/12/2023 10:17:53 AM(UTC)
Kenmore 796 40441900 Wont Start, but... (Washer Repair)
by EmitRDetsaw 1/2/2023 11:16:21 AM(UTC)
Replaced belt, idler pulley, and rollers and now Maytag Dryer Wont Start (Dryer Repair)
by Guest 11/29/2022 8:43:07 PM(UTC)
dishwasher lights flash but wont start (Dishwasher Repair)
by markshelp 11/20/2022 8:12:38 AM(UTC)
KMBS104ESS02 wont start. Some buttons unresponsive (Microwave Repair)
by Guest 7/10/2022 1:22:03 PM(UTC)
Kenmore Stacked combo washer wont start after heavy load :( 110.88752796 (Washer Repair)
by puppy10014 10/22/2021 9:23:07 AM(UTC)
my Kenmore Dishwasher wont start (Dishwasher Repair)
by Guest 6/14/2021 8:14:07 AM(UTC)
Samsung dv40j3000ew/a2 wont start after motor replacement (Dryer Repair)
by rev1id 3/24/2021 7:38:30 PM(UTC)
GE Cafe edition Dishwasher Wont start (Dishwasher Repair)
by Lorunner1213 10/1/2019 12:04:27 PM(UTC)
KENMORE Fridge Wont Start Till I punch the thermostat Control (Refrigerator & Freezer Repair)
by kami009 7/5/2019 10:21:20 AM(UTC)
Whirlpool oven & broiler wont start (Oven Repair (including Ranges and Cooktops))
by rstonina 5/13/2019 12:35:09 PM(UTC)
Maytag Dryer wont start (Dryer Repair)
by rscottc 5/27/2018 10:49:05 PM(UTC)
Dryer Elite wont start (Washer Repair)
by pkeresz 4/2/2018 11:06:18 AM(UTC)
Freezer Wont Start (Refrigerator & Freezer Repair)
by curtis68 2/3/2018 1:54:34 PM(UTC)
GE Dryer wont start (Dryer Repair)
by bob35614 2/13/2017 4:21:03 PM(UTC)
