Outtasite
#1 Posted : Saturday, January 16, 2010 3:59:10 PM(UTC)
Outtasite
The fill valve won't stop filling and water overflows out the door even after machine is turned off. I have checked the overflow prevention device and believe it to be working correctly. I recently changed the shut off valve under the sink, but I don't see how that could be related. Please help.
#2 Posted : Sunday, January 17, 2010 12:26:57 AM(UTC)
Replacement parts for WHIRLPOOL DU6000XR1 | AppliancePartsPros.com
Sounds like some crud came loose when you replaced the shut-off and was able to get past the fill valve's screen filter. This is now holding the valve open.
I would replace the units fill valve.
tresaq11
#3 Posted : Friday, January 22, 2010 10:31:54 AM(UTC)
tresaq11
Is this part what is called "water Inlet Valve" ?
#4 Posted : Wednesday, January 27, 2010 12:59:29 AM(UTC)
Part number: AP3050333
Item 26 in Section 2
Sorry for the delay was stuck at the lake due to a storm
